I2C comunication
Hi to everyone!!! I had start to work with I2C comunication between Arduinos and it looks relly good and easy to make same simple projects..
Now I want to make I2C communication between arduino and an xmega microcontroller.. I don't now if it's possible???..
I want to read three registers from xmega, with arduino as master and xmega as slave.. the address from xmega registers are 0x11 , 0x21, 0x31...
The addresses for read xamega is 0xC1 and write with this address 0xC0.. I tried to do this project with Wire library but I didn't find the way to make it work..
Could anyone tell me if that is possible?? if yes, could you suggest me what to do!!!
(Im new in C++ programming)
Thanks!!
Kind regards!!
Well, you know that the Arduino can send and receive. The xmega thing is NOT an Arduino, and programming it is not a topic for discussion here.
Sorry! I didn't know that..
Im new in this forum..
Where is the right place?
On the xmega controller forum.
The xmega is already programmed..
I need to programm arduino to read from xmega and to write to xmega..
I read "Wire" library and it works well with arduino to arduino communication..I don't know if it's possible for arduino and a different microcontroller..
You already had answers here, and still you went ahead and posted the exact same question in a different section?
