Hey All, I've recently got into I2C Between a Nano (Master) and Uno (Slave) and its working for the most part. All the connected LEDs turn on Slave side but wont flash or at the very least flicker when I drop the delay to a lower value.
and secondly, How would I be able to keep these ON when their buttons (Master side) are triggered and then turn them OFF when I press it again?
MASTER
#include <Wire.h>
const int slaveAddress = 1;
int BTN1 = 2;
int BTN2 = 3;
int BTN3 = 4;
int BTN4 = 5;
int BTN5 = 6;
int BUTTON1 = 0;
int BUTTON2 = 0;
int BUTTON3 = 0;
int BUTTON4 = 0;
int BUTTON5 = 0;
Wire.begin();
pinMode(BTN1, INPUT_PULLUP);
pinMode(BTN2, INPUT_PULLUP);
pinMode(BTN3, INPUT_PULLUP);
pinMode(BTN4, INPUT_PULLUP);
pinMode(BTN5, INPUT_PULLUP);
Wire.beginTransmission(slaveAddress);
BUTTON1 = digitalRead(BTN1);
BUTTON2 = digitalRead(BTN2);
BUTTON3 = digitalRead(BTN3);
BUTTON4 = digitalRead(BTN4);
BUTTON5 = digitalRead(BTN5);
Wire.write(BUTTON1);
Wire.write(BUTTON2);
Wire.write(BUTTON3);
Wire.write(BUTTON4);
Wire.write(BUTTON5);
Wire.endTransmission();
// delay(500);
SLAVE
#include <Wire.h>
int ledPin = A0; // the pin that the LED is attached to
int ledPin1 = A1; // the pin that the LED is attached to
int ledPin2 = 2; // the pin that the LED is attached to
int ledPin3 = 3; // the pin that the LED is attached to
int ledPin4 = 4; // the pin that the LED is attached to
int ledPin5 = 5; // the pin that the LED is attached to
int ledPin6 = 6; // the pin that the LED is attached to
int ledPin7 = 7; // the pin that the LED is attached to
int ledPin8 = 8; // the pin that the LED is attached to
int ledPin9 = 9; // the pin that the LED is attached to
int ledPin10 = 10; // the pin that the LED is attached to
int ledPin11 = 11; // the pin that the LED is attached to
int ledPin12 = 12; // the pin that the LED is attached to
int ledPin13 = 13; // the pin that the LED is attached to
int BUTTON1 = LOW;
int BUTTON2 = LOW;
int BUTTON3 = LOW;
int BUTTON4 = LOW;
int BUTTON5 = LOW;
Wire.begin(1);
Wire.onReceive(receiveEvent);
pinMode(ledPin, OUTPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
pinMode(ledPin5, OUTPUT);
pinMode(ledPin6, OUTPUT);
pinMode(ledPin7, OUTPUT);
pinMode(ledPin8, OUTPUT);
pinMode(ledPin9, OUTPUT);
pinMode(ledPin10, OUTPUT);
pinMode(ledPin11, OUTPUT);
pinMode(ledPin12, OUTPUT);
pinMode(ledPin13, OUTPUT);
//Nothing
void receiveEvent(int howMany){
BUTTON1 = Wire.read();
BUTTON2 = Wire.read();
BUTTON3 = Wire.read();
BUTTON4 = Wire.read();
BUTTON5 = Wire.read();
if (BUTTON1 == LOW){
digitalWrite(ledPin4, HIGH);
digitalWrite(ledPin12, HIGH);
digitalWrite(ledPin4, LOW);
digitalWrite(ledPin12, LOW);
digitalWrite(ledPin8, HIGH);
digitalWrite(ledPin3, HIGH);
digitalWrite(ledPin8, LOW);
digitalWrite(ledPin3, LOW);
if (BUTTON2 == LOW){
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin1, HIGH);
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin6, HIGH);
digitalWrite(ledPin7, HIGH);
digitalWrite(ledPin10, HIGH);
if (BUTTON3 == LOW){
digitalWrite(ledPin5, HIGH);
digitalWrite(ledPin9, HIGH);
digitalWrite(ledPin11, HIGH);
if (BUTTON4 == LOW){
if (BUTTON5 == LOW){
if (BUTTON1 == HIGH && BUTTON2 == HIGH && BUTTON3 == HIGH && BUTTON4 == HIGH && BUTTON5 == HIGH) {
digitalWrite(ledPin, LOW);
digitalWrite(ledPin1, LOW);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin5, LOW);
digitalWrite(ledPin6, LOW);
digitalWrite(ledPin7, LOW);
digitalWrite(ledPin9, LOW);
digitalWrite(ledPin10, LOW);
digitalWrite(ledPin11, LOW);
digitalWrite(ledPin13, LOW);
