I2c data from diferent address
Hello, i´m trying to read the information that gives an 7 segment display. this display is sending the information to a mux TM1650 (in other board) and when i check the address´s founded out that every number (3) are in different address. so, what im doing is to conect de arduino to the sda and scl of the tm 1650. I was trying something like this:
#include <Wire.h>
#include <pt.h>
static struct pt pt1, pt2, pt3;
  int a;
  int b;
  int c;
  PT_INIT(&pt1);
  PT_INIT(&pt2);
  PT_INIT(&pt3);
  Serial.begin(9600);           // start serial for output
  hilo1(&pt1);
  hilo2(&pt2);
  hilo3(&pt3);
  delay(100);
  suma(a,b,c);
void hilo1(struct pt *pt){
  PT_BEGIN(pt);
  Wire.begin(52);                // join i2c bus with address #52
  Wire.onReceive(receiveEvent); // register event
  PT_END(pt);
void hilo2(struct pt *pt){
  PT_BEGIN(pt);
  Wire.begin(53);                // join i2c bus with address #53
  Wire.onReceive(receiveEvent2); // register event
  PT_END(pt);
void hilo3(struct pt *pt){
  PT_BEGIN(pt);
  Wire.begin(54);                // join i2c bus with address #54
  Wire.onReceive(receiveEvent3); // register event
  PT_END(pt);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
 int receiveEvent(int howMany) {
 a = Wire.read();    // receive byte as an integer
  return a;
int receiveEvent2(int howMany) {
 b = Wire.read();    // receive byte as an integer
  return b ;
int receiveEvent3(int howMany) {
 c = Wire.read();    // receive byte as an integer
  return c;
void suma(int a, int b, int c){
  Serial.print(a); Serial.print(" - ");Serial.print(b);Serial.print(" - "); Serial.println(c);
  delay(100);
but when i print it , it just print the last wire information.
any suggestion?
ps: is my first time in the forum, so srry if i thit something wrong with the forum politics
ps2: the display is showing temperature
Being Your first post You used code tags! Well done! Karma++.
What Do You mean by "last wire information? Is only "c" value printed?
The code looks clean and ought to work. It's late here and I don't see any obvious mistake.
Thanks! , yep it just print "c" value , and the others valus stay in 0 value (default).
Strange. What if You omit the call updating c? Only calling updating a and b?
Could it be something from how and where a, b and c are declaref? I do like that and it works.
Can it be how You reference the elements inside the struct pt? Maybe &pt.pt1 etc.?
Show us pt.h
pt.h is the library protothreads and i based my self in there examples.
Maybe it is where a, b and c are declared but i dont know where else to declare it , because if i just declare it inside there own functions, the program shows an error on void suma() because it has no declare a,b or c.
and when i tryied to ommit c , it just update b. So, the program just shows the last Wire that i begin.
aarg:
Show us pt.h
pt.h is available in the library manager and also, in here:
http://dunkels.com/adam/pt/download.html
cmatons:
Protothreads - download
The library file to download is Version 1.4: pt-1.4.tar.gz BUT the file is not actually compressed with gzip. It is just a tar file without any compression.
