I2C device addressing
I've searched google and this forum but it seems no-one else is working with many Arduinos connected together via I2C.
I'd like to have one master Arduino node and many (say 32) Arduino's connected to that master via I2C. They are all I2C slaves and they all would be running the exact same software.
The question I have is simple: How do I allocate each slave Arduino with a unique address if they are all running the same .elf?
If each slave was running different software, I would hardcode the address of each slave in each project and all would work ok, but this simple problem is stumping me.
A few other ways to pose the same question:
  • how can I get each slave to retrieve a unique address from the master node?
  • how can I get each slave to self-allocate a unique address?
  • how can I send each slave a unique address from the master node before it has an I2C address allocated to it?
All help will be greatly appreciated!
JohnA
You can have input pins on each arduino, for 32 devices you will need five of them. You then short out a unique combination to ground on each device. Your code then reads these pins and so gives itself an address.
Or maybe perhaps a small trimmer pot mounted on each board that supplies an adjustable voltage to a analog input pin. Each board reads its uniquely adjusted voltage and if in a narrow range supplies itself a unique address based on some calculation that results in a 1 to 127 address. Might not be all that simple from a software point of view, but simple and easy on the hardware resources required.
Lefty
There is a protocol called SM-Bus (similar to and derived from I2C) which support dynamic address assignment (the protocol is widely used to support plug-and-play style identification).
Address assignment is based on slaves initially connecting to the I2C master with an address request. Data passed on with the request include a unique identifier (similar to MAC as we know from Ethernet). The master will then allocate and return a free and unique address to the slave. A mapping table on the master is used to correlate the slave unit and address for subsequent master initiated comnmunication. This would solve the issue with I2C address assignment, but you would still need to program each slave with a unique identifier. This could be in EEPROM however and so separate from the application.
If you are going to do that then why not just store an address in the first place.
BenF: thanks for the heads up. I looked at the SMBus and ARP is exactly what I need. From the SMBus protocol spec it seems that it is possible to get an address even without a DUID or I could generate one randomly. In any case, I couldn't find an SMBus library for the Arduino however. Do you happen to have any links?
This post Arduino Forum claims to implement an "I2C address scanner". The idea is that the master goes through all 120 addresses and either gets a response (and therefore an existing address) or doesn't and therefore that address is free. Essentially this gives me device enumeration like the SMBus has.
Another thought is: what if all the slave Arduino's initially start off with a known address (say 01). Then the master periodically checks if any devices are at address 01. The first one to respond is allocated the next free address.
I have seen a lot of sites explaining that all devices have to have a unique address but it is unclear exactly what happens if (by accident say) two devices have the same address.
One way around this is to have all of the devices with address 01 do a random delay before responding. The likelihood of more than one device being the first to respond is very low; generally only one device will win and be first. It seems from the scanner code, that this is not possible but I thought I'd ask anyway.
JohnA
johnA:
A scanner can only tell you for sure that no one responded to a specific address, but it won't be able to tell if two or more I2C slaves are responding to the same address, there is no collision avoidance protocol in the I2C standard.
There is not 'first one to respond', all slaves with starting address of 01 will try and respond at the very same time, results in garbage data as the slaves step all over each other.
The slaves step on each other and garbage data results and the master has no idea why.
Your trying to wish that I2C was a more powerful protocol then it is. By some method you have to make sure each slave starts up life with a unique address, It can't be orchestrated at start-up by the master and the slaves can't talk to each other to negotiate unique address assignments. You need to do it with either separate sketches for each slave, or some hardware method on each slave board or have a unique address pre written into its EEPROM, etc.
JohnA
This can work but only if you are happy to add a single node at a time when you first set the system up. The new node gets its address then you add the next one etc etc.
Rob
Well yes, but less like wishing and more like hacking.
The reason I think it is even possible is that the slave devices here are Arduino's and not simple chips. This opens some possibilities. For example:
Therefore it might be possible (within the defined I2C spec) to do the following:
master is also a slave at reserved address 01
all slaves start using reserved address 02, or the address saved in its EEPROM (03 to 120)
// see if any slaves are unallocated
master: send a broadcast - Start Allocation message
all slaves with address 02: delay for random number of microseconds
slaveA (as master): creates a 32-bit random number and sends it to master 01
master 01: associates the random number with next free address
slaveB (as master): creates a 32-bit random number and sends it to master 01
... repeat until some_magic_condition occurs...
// Assign the addresses
master: send a broadcast - Start Assignment message
master: broadcasts slaveA's random number and address
slaveA: sets it's address to the given address; saves the address in its EEPROM
master: broadcasts slaveB's random number and address
slaveB: sets it's address to the given address; saves the address in its EEPROM
... repeat ...
// do it again, just in case
no slaves with address 02 should remain
if there are any remaining, then this step should allocate them
// enumerate the slaves
master: this should catch both the newly allocated addresses plus the previously saved addresses.
Looks clunky but might work...
John
How do they know another slave/master has not already started transmitting? Is there a mechanism in I2C to handle that?
Rob
Of course not.
The OP seems supremely confident that he can hack the I2C bus protocol. All attempts to discourage / enlighten him seem to fail. He is bringing out all the old bus ideas that were rejected long ago. I don't know maybe he is young and doesn't realise many people have been round that block many times before. Simply the wrong protocol for the job.
I think that the first hint to his impending doom was the statement that he wanted ALL nodes running exactly the same software...
He could use I2C to have master assigned slave addresses, by controlled sequential startup of the slaves, as example. But, there is just too much sugar for a dime in what he says that he wants to do... Keep it simple and it will work better.
Best solution to multiple slaves is node dependent software, hardcoded addressing at the very least. Otherwise, WHY HAVE MULTIPLE SLAVES if they are all doung the same thing and calling home with the same names???
That's a reasonable requirement and doable and I understand why he wants to get away from having hardcoded and unique values programmed into each node, especially if this will be a product where maybe you don't know in advance how many will be plugged in and holding inventory of nodes with hardcoded addresses would be difficult.
I have a similar requirement at present (not with I2C) but the only way I know to do it is to bring the nodes online one at a time or "by controlled sequential startup of the slaves" as you say. As this is a one-off thing when you first build a system I think that's a reasonable approach.
Rob
Graynomad:
The AtMega's support HW multi-master bus arbitration. The scheme is based on masters listening for bus activity (start/stop) and then only claim the bus when idle. This generally works when arbitration is only required once every blue moon, but it will not work when two or more devices try to claim the bus at the exact same clock edge (such as may be the case when multiple identical devices are powered on at the same time). For this some software retry scheme will be required.
For most practical purposes (as opposed to academic), storing a unique address in EEPROM is a good option.
Well you are living up to your moniker! Which is cool with me by the way, too much PC BS these days.
It's been a long time since anyone's called me anything close to "supremely confident". I going to have to take it as a compliment. So thanks, appreciate it!
Not young. Here's a hint: I bought a Motorola 6800/MIKBUG based computer for $1K in 1976 just after I graduated from high school. Taught myself how to program machine language (hand assembled of course). No it wasn't an Altair, a Commodore, a PET or an Apple I - the 6502 had just come out and the Z-80 was the next big thing.
I agree the SMBus is the right way to go. However it isn't clear if there is an Arduino library for it. If the SMBus and I2C are "compatible" as the Intel blurbs say, then I should be able to use I2C to replicate the SMBus protocol (which implies that someone from Intel "hacked" I2C to come up with SMBus). But that doesn't sound like a pleasant thing to do.
I don't need a "controlled sequential startup" at all. I just want the master to assign the slave addresses.
I agree that storing the addresses in EEPROM is easier. But being nuts is more fun. And besides once an address is assigned to a slave, it can be stored in EEPROM and the whole situation becomes sane again.
[quote\Otherwise, WHY HAVE MULTIPLE SLAVES if they are all doung the same thing and calling home with the same names???[/quote]
It is very reasonable to have a large array of slaves doing all the same thing. It is very unreasonable to have them call home with the same address -- that's why I'd like to have the addresses assigned by the master.
As BenF says, multi-master bus arbitration is available on the AtMega. Still unknown if the Arduino I2C library can handle it in a reasonable way.
The link I gave clearly shows that it is possible for an Arduino to be both Master and Slave at the same time (unless that guy was throwing some BS out into the ether).
Like I said, those two aspects open up a lot of opportunities....
I think the scheme I proposed would prevent them from hitting the exact same clock edge nearly all the time, but there is a very small probability it could happen. Each slave is quiet until the master kicks the process off with the first message. The slaves all back off randomly, so with high probability, the first slave to respond after that will be the only one to respond. If the other slaves don't blindly rush forward at that point, then there will be a second slave to respond, and again with high probability the only one to respond. And so on.
This process will be slow, but once they have their addresses in EEPROMs, it doesn't need to occur again until a brand new device is added to the array.
Yes, as long as the collision can reliably be detected by all the colliding parties. If so, then random back-off would work, even if it had to be repeated until it did. It all depends on the Arduino's I2C library ability to handle collisions in a clear and reasonable way.
JohnA
johnA:
That would be me, I think. :slight_smile:
You sound like you must be my age or thereabouts.
Can you define the problem more clearly? You want multiple slaves running the same software. So far so good. Are you gradually going to add them? You could have some sort of "give me an address" button that, when pressed, asks the master for a free address, and then writes that into EEPROM.
The master could do a broadcast (address 0). I'm not too clear about whether multiple slaves of the same address would cause a problem there, but I suspect not (need testing to confirm).
The broadcast could be "any slaves need an address?". The slaves could then wait a random time and then respond. Hopefully one will get in sooner and be assigned an address before the others respond. I think it is achievable, but there might be simpler ways. Like, a simple program that writes a slave address to EEPROM before deploying the "main" program.
Remember, you don't have heaps of program memory. You don't want to take half of it up with a smart "address allocation" routine if there are simpler ways.
Excellent! You weren't throwing BS into the ether were you? (*)
I was going to make a crack about an Age Check for posting to this forum but I won't.
Not really, I was hoping to add them all at once. But I guess the scenario would come up: I run to one Radio Shack, wipe out their store's inventory of Arduino's, add the batch of them to the existing array, run to the next Radio Shack, etc., having the NSA show up at my door asking why I'm buying all the damn Arduinos.
It would be interesting to work out a "hot plug" like scheme though...
In short, I was just balking at the sheer number. Trying to keep a dozen, let alone 32, identical boards straight and having absolutely no address collision when doing that manually, just seems... unlikely.
That sounds much easier but not as much fun! If a nice software solution doesn't fall out, I'll probably use this and maybe light an LED to indicate the board is missing an address.
In your testing for your site, did you run any multiple master configurations? I'm very curious on what the Arduino I2C library does in that case.
I bet it would be very difficult to set up a test. There would have to be some other artificial mechanism to get multiple boards to reliably start communicating at exactly the same time.
Good point. But my experience has been that half the fun is dreaming these things up and the other half is, once in a while, an elegant solution just comes out of the conversation that solves everything quite nicely. In the meantime, we're poking at I2C and finding the limits of it's capabilities. Seems win-win to me.
In any case, got to go...
(*) My humour style is deadpan hyperbole. May not translate into ASCII very well; I haven't checked Unicode. Anyone visiting your site knows my comment was tongue-in-cheek.
Use an LPC processor, they have a unique ID burned into the silicon. :slight_smile:
Rob
I still do not see that you can avoid collisions, even with your random back-off idea. You have no garantee without some external control/arbitration. My first response is to do it the simple way with EPROM'd addresses, but I also see that that does not facilitate adding of devices in an easy manner.
And,, I get the impression that you are trying to learn from doing it the hard way (most commendable).
If you do get it to work, I, for one, would be interrested in how you went about it ( I don't want to see your code, I just want to hear you explain the logic that made it work). Good Luck. I hope to see notice of your success.
One of my code samples had both ends acting as a master. It's quite possible as such, I2C doesn't really have a master, more like "I'm master right now".
I didn't try too hard to get collisions. It wouldn't have been ... fun.
The protocol itself is supposed to detect it, but of course you would want to randomize a retry a bit, or they would keep happening.
There was a guy here a while back who posted a whole lot of boards connected together to do different things (they weren't identical). He used I2C, but I think he had a "assign me an address" button to work around the problem you are describing.
