I2c device disappear from bus after writing
Hi!
I am currently experiencing a really odd I2C problem on a Atmega32u4 based card. I'm trying to use a TLV493D connected by I2C. I know from this thead that before using this device, I have to set the powermode :
Wire.beginTransmission(HallAddressWrite);       // Address the sensor
Wire.write(configReg);              // Address the Configuration register
Wire.write(powerMode);              // Set the Power Mode to Low
errorCode = Wire.endTransmission();             // Stop transmitting
But each time I'm trying to write on the TLV493D register, the device simply disappear from I2C bus ! I know it sounds strange, but I can demonstrate it with a modified version of default I2C scanner default I2C scanner
if (error == 0)
  Serial.print("I2C device found at address 0x");
  if (address<16)
    Serial.print("0");
  Serial.print(address,HEX);
  Serial.println("  !");
  Serial.println("Beginning write test...");
  Wire.beginTransmission(address);
  // no register writing
  Serial.print("Test ended with code : ");
  Serial.println(errorCode);
  Serial.println("SECOND Beginning write test...");
  Wire.beginTransmission(address);       // Address the sensor
  Wire.write(0x00);              // Address the Configuration register
  Wire.write(0x05);            // Set the Power Mode to Low
  nDevices++;
which gives the output:
I2C device found at address 0x5E  !
Test ended with code : 0
And next scan doesn't find anything. As you can see, I don't lost my device when I don't write anything. But it disappears from my bus as soon as I write something (here, it's for setting low power mode, but any value will do the same).
More informations :
  • My code is correct. I know that because I don't have any problem when using an Arduino Uno or Arduino Mega. Unfortunately, I don't have an Arduino Leonardo to see if my problem comes from Atmega32u4.
  • My wiring is correct. I checked the signal on SDA and SCL pin on the TLV493D with an oscilloscope and everything is as expected : 3.3V and 100kHz.
  • I also have a SRF02 on my I2c bus : it is working as expected.
  • I don't think my TLV493D is damaged. In deed, I thought it was because of that. So I changed it for another one but the problem is still here.
  • I noticed than when beginning an I2C transmission at address 0x00, I am able to see my TLV493D again. But it is pointless since I have to set power mode again and thus, it disappears from bus once again.
  • I checked supply voltage and it stays constant at 3.3V. So I don't think I a have tension drop tht would provok TLV493D reset
Thank you.
you have an answer on Arduino SE atmega32u4 - I2c device disappear from bus after writing - Arduino Stack Exchange
