My OLED is not working I've all the connections right still no output on the OLED I tried the header file solution along with x3C & x3D solution still it is not working can any one guide please? I'm using the example I2c scanner code which is easily available on the internet.
How is this a tutorial? As it does not look like one, your topic has been moved to a more suitable location on the forum.
Please provide the details of your hardware (display, Arduino) and the connections. Please post the "example scanner" code here; I (and most others) are not going to hunt for it on the internet with the risk that we find the wrong one and base replies on the one we found.
The following test sketch works fine in my OLED.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS))
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(2000); // Pause for 2 seconds
// Clear the buffer
display.clearDisplay();
// Draw a single pixel in white
display.drawPixel(10, 10, SSD1306_WHITE);
// Show the display buffer on the screen. You MUST call display() after
// drawing commands to make them visible on screen!
display.display();
delay(2000);
testdrawstyles(); // Draw 'stylized' characters
void testdrawstyles(void)
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(0, 0); // Start at top-left corner
display.println(F("Hello, world!"));
//(SSD1306_BLACK, SSD1306_WHITE); // Draw 'inverse' text
display.println(3.141592, 6); //6-digit after decimal point
display.setTextSize(2); // Draw 2X-scale text
display.print(F("0x")); display.println(0xDEADBEEF, HEX);
display.display();
delay(2000);
My OLED started working after a restart, thank you for the support it was a 128_32 OLED
