I2C device not recognized
Hi everyone,
I'm a complete newbie at Arduinos. For my project, I'm trying to implement I2C communication between two Arduinos: the master is an Arduino Mega, and the slave is an Arduino Uno WiFi Rev2. I'm reading the LSM9DS1 sensor from the master, and sending the signal outputs to the slave through I2C.
The problem I have is when I connect both the IMU sensor and the arduino slave to the same I2C channels, my master doesn't recognize the arduino slave while it can still read the IMU. When I disconnect the IMU, it starts recognizing the arduino slave again and I can send arbitrary messages to the slave in the format that I want. I tried to fix the problem by setting the clock speed to 50kHz, adding 10k pull up resistors to the SDA and SCL pins but nothing worked.
In the future, I'm planning to add more sensors and LCD displays to the same I2C bus, but I'm having problem with even only one sensor. Could someone please help me with this ? If more information is needed, I'd be happy to share.
I suggest you read the specification at: https://www.nxp.com/docs/en/user-guide/UM10204.pdf it explains the whole thing. I2C was never intended for inter processor communications. Any wires over 25cm/10" will cause problems. Try 4.7K pull up resistors. Also run the I2C scanner and let us know the results.
Can you find a project that has a Arduino Uno WiFi Rev2 as a I2C Slave ?
why not connect the LSM9DS1 sensor (and other devices) to the Uno WiFi Rev2 amd dump the mega
having to program two microcontrollers and the resultant communications makes the overall task complexity an order of magnitude greater
Please, post the sketches with code tags (</>) for both Master and Slave.
As I see in the pdf, there is a set-up example with two microcontrollers and a bunch of other devices connected to the bus:
I unfortunately have only 10k resistors. My I2C scan result is:
I2C device found at address 0x1E
I2C device found at address 0x6B
I guess 0x1E and 0x6B are for IMU since it's a 9DOF. When I disconnect IMU, my result changes to:
I2C device found at address 0x09
My master:
// Libraries
#include <Arduino.h>
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LSM9DS1.h>
#include <Adafruit_Sensor.h>  // not used in this demo but required!
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
// Constants
// Motor signal channels
const int channel4 = 2;  // steering (yellow cable)
const int channel2 = 3;  // acceleration (purple cable)
const int s1 = 6;   // acceleration // Connect this to S1 on the Sabertooth (purple cable)
const int s2 = 7;   // steering     // Connect this to S2 on the Sabertooth (yellow cable)
// Speed limits
const int defaultSpeed = 185;  // Default motor speed (0-370)
const int upperLimit = 355;
const int lowerLimit = 15;
float deadZone = 10;  // Adjust this value for changing the deadzone where the motors act with the default speed
float filteredCh1 = defaultSpeed;  // Initial values (adjust as needed)
float filteredCh2 = defaultSpeed;
// Remapping Values
const int MAX_PPM=1000;
const int MIN_PPM=2000;
int remappedMaxPPM = 370;
int remappedMinPPM = 0;
// Control filter constants
const float alpha = 0.2;  // Smoothing factor (adjust for setting the weight of the current readings) default:0.2
// IMU filter constants
const float alpha9DOF = 0.15; // Weight for accelerometer data
const float gamma9DOF = 0.2; // Weight for magnetometer data
const float beta9DOF = 0.02;  // Weight for gyroscope data
// Error constants
const float ACC_ANGLE_ERROR_X = 0.01;
const float ACC_ANGLE_ERROR_Y = 0.01;
const float ACC_ERROR_X = 0.13;
const float ACC_ERROR_Y = 0.01;
// Initialization
// IMU initialization
Adafruit_LSM9DS1 lsm = Adafruit_LSM9DS1(); //0x1E, 0x6B
float filteredAccelX = 0.0;
float filteredAccelY = 0.0;
float fusedAngleX = 0.0;
float fusedAngleY = 0.0;
// Serial communication object through the digital pins
TinyGPSPlus gps; // The TinyGPS++ object
static const int gpsRXPin = 8, gpsTXPin = 9; // Communication pins of the gps module
static const int unoRXPin = 10, unoTXPin = 11; // Communication pins between mega and uno
SoftwareSerial ss(gpsRXPin, gpsTXPin);
SoftwareSerial unoSerial(unoRXPin, unoTXPin);
float message=0;
// I2C Initialization
#define SLAVE_ADDR 9
#define ANSWER_SIZE 26
#define MESSAGE_COUNT 3
// Time stamp
unsigned long interval = 0;
struct Values {
  float readingCh1;
  float readingCh2;
  float remappedReadingCh1;
  float remappedReadingCh2;
  float filteredCh1;
  float filteredCh2;
  float fusedAngleX;
  float fusedAngleY;
  bool readingGps;
Values readingValues ;
Values remappedValues ;
Values filteredValues ;
Values readingImuValues ;
Values readingGps ;
void setupSensor()
  // 1.) Set the accelerometer range
  lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_2G);
  //lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_4G);
  //lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_8G);
  //lsm.setupAccel(lsm.LSM9DS1_ACCELRANGE_16G);
  // 2.) Set the magnetometer sensitivity
  lsm.setupMag(lsm.LSM9DS1_MAGGAIN_4GAUSS);
  //lsm.setupMag(lsm.LSM9DS1_MAGGAIN_8GAUSS);
  //lsm.setupMag(lsm.LSM9DS1_MAGGAIN_12GAUSS);
  //lsm.setupMag(lsm.LSM9DS1_MAGGAIN_16GAUSS);
  // 3.) Setup the gyroscope
  lsm.setupGyro(lsm.LSM9DS1_GYROSCALE_245DPS);
  //lsm.setupGyro(lsm.LSM9DS1_GYROSCALE_500DPS);
  //lsm.setupGyro(lsm.LSM9DS1_GYROSCALE_2000DPS);
  Wire.begin();
  ss.begin(9600);
  pinMode(channel4,INPUT);
  pinMode(channel2,INPUT);
  analogWrite(s1, defaultSpeed);
  analogWrite(s2, defaultSpeed);
  while (!Serial) {
    delay(1); // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("LSM9DS1 data read demo");
  // Try to initialise and warn if we couldn't detect the chip
  if (!lsm.begin())
    Serial.println("Oops ... unable to initialize the LSM9DS1. Check your wiring!");
    while (1);
  Serial.println("Found LSM9DS1 9DOF");
  readingValues = readPPM(channel4, channel2);
  remappedValues = remap(readingValues.readingCh1, readingValues.readingCh2);
  filteredValues = lowPassFilter(remappedValues.remappedReadingCh1, remappedValues.remappedReadingCh2);
  writePPM(filteredValues.filteredCh1, filteredValues.filteredCh2);
  readingImuValues = readImu();
  // Values readingGpsValues = readGps();
  // I2C(filteredValues.filteredCh1);
  // I2C(filteredValues.filteredCh2);
  static unsigned long previousMillis = 0;
  unsigned long interval = currentMillis - previousMillis;
  //  Serial.println(interval);
  if (interval > 15000) {
    for (float i = 0; i < MESSAGE_COUNT; i++) {
      prepareMessage(i);
    previousMillis = currentMillis;  // Update the last time the action was performed
  // delay(3000);
Values readPPM(int channelInput1, int channelInput2) {
  int ch1Reading = pulseIn(channelInput1, HIGH);
  int ch2Reading = pulseIn(channelInput2, HIGH);
  Values result;
  result.readingCh1 = ch1Reading;
  result.readingCh2 = ch2Reading;
  return result;
Values remap(int channelInput1Reading, int channelInput2Reading ) {
  int ch1RemappedReading = map(channelInput1Reading, MAX_PPM, MIN_PPM, remappedMaxPPM, remappedMinPPM);
  int ch2RemappedReading = map(channelInput2Reading, MAX_PPM, MIN_PPM, remappedMaxPPM, remappedMinPPM);
  Values result;
  result.remappedReadingCh1 = ch1RemappedReading;
  result.remappedReadingCh2 = ch2RemappedReading;
  return result;
Values lowPassFilter(int remappedCh1Input, int remappedCh2Input) {
  filteredCh1 = alpha * remappedCh1Input + (1 - alpha) * filteredCh1;
  filteredCh2 = alpha * remappedCh2Input + (1 - alpha) * filteredCh2;
  // Upper-lower limits
  if (filteredCh1 > upperLimit) {
    filteredCh1 = upperLimit;
  } else if (filteredCh1 < lowerLimit) {
    filteredCh1 = lowerLimit;
  if (filteredCh2 > upperLimit) {
    filteredCh2 = upperLimit;
  } else if (filteredCh2 <= lowerLimit) {
    filteredCh2 = lowerLimit;
  // Deadzone
  if (abs(filteredCh1 - defaultSpeed) < deadZone) {
  if (abs(filteredCh2 - defaultSpeed) < deadZone) {
  Values result;
  result.filteredCh1 = filteredCh1;
  result.filteredCh2 = filteredCh2;
  return result;
void writePPM(int filteredCh1Input, int filteredCh2Input) {
  analogWrite(s1, filteredCh2Input);
  analogWrite(s2, filteredCh1Input);
Values readImu() {
  lsm.read();  /* ask it to read in the data */
  /* Get a new sensor event */
  sensors_event_t a, m, g, temp;
  lsm.getEvent(&a, &m, &g, &temp);
  // Calculate pitch angle from accelerometer data
  filteredAccelY = alpha9DOF * a.acceleration.y + (1 - alpha9DOF) * filteredAccelY;
  filteredAccelX = alpha9DOF * a.acceleration.x + (1 - alpha9DOF) * filteredAccelX;
  float accelAngleX = (atan((filteredAccelY)/sqrt(pow((filteredAccelX + ACC_ERROR_X),2) + pow((a.acceleration.z),2)))*RAD_TO_DEG) - ACC_ANGLE_ERROR_X;
  float accelAngleY = (atan(-1*(filteredAccelX)/sqrt(pow((filteredAccelY),2) + pow((a.acceleration.z),2)))*RAD_TO_DEG) - ACC_ANGLE_ERROR_Y;
  // Calculate gyroscope-based change in pitch angle
  float gyroRateX = g.gyro.x * DEG_TO_RAD;
  float gyroRateY = g.gyro.y * DEG_TO_RAD;
  // Complementary filter to combine accelerometer and gyroscope data
  fusedAngleX = alpha9DOF * (gyroRateX + fusedAngleX) + (1-alpha9DOF) * accelAngleX;
  fusedAngleY = alpha9DOF * (gyroRateY + fusedAngleY) + (1-alpha9DOF) * accelAngleY;
  // Calculate yaw angle from magnetometer data
  float filteredYawAngleY = 0;
  float filteredYawAngleX = 0;
  filteredYawAngleY = gamma9DOF * m.magnetic.y + (1 - gamma9DOF) * filteredYawAngleY;
  filteredYawAngleX = gamma9DOF * m.magnetic.x + (1 - gamma9DOF) * filteredYawAngleX;
  float yawAngle = atan2(filteredYawAngleY, filteredYawAngleX) * RAD_TO_DEG;
  // Integrate accelerometer data to get velocity (simplified, assuming constant acceleration)
  static float velocity = 0.0;
  velocity += a.acceleration.x * 0.02; // 0.02 is the time between loops in seconds
  Values result;
  result.fusedAngleX= fusedAngleX;
  result.fusedAngleY= fusedAngleY;
  // Serial.println("x=");
  // Serial.println(fusedAngleX);
  // Serial.println("y=");
  // Serial.println(fusedAngleY);
  return result;
void prepareMessage(float messageID)
  if(messageID==0){
    message=readingImuValues.fusedAngleX;
    // message=11;
  else if(messageID==1){
    message=readingImuValues.fusedAngleY;
    // message=12;
  else if(messageID==2){
    message=remappedValues.remappedReadingCh2;
    // message=13;
  byte byteArray[sizeof(float)*MESSAGE_COUNT];  // Byte array to hold the converted float
  // Convert message ID to byte array
  memcpy(byteArray, &messageID, sizeof(messageID));
  // Convert message data to byte array
  memcpy(byteArray + sizeof(messageID), &message, sizeof(message));
  sendWireData(byteArray, messageID, message);
  Serial.print("Message sent => ID: ");
  Serial.print(messageID);
  Serial.print(" Data: ");
  Serial.println(message);
void sendWireData(byte* byteArray, float messageID, float message){
  Wire.beginTransmission(SLAVE_ADDR);
  Wire.write(byteArray,sizeof(byteArray)); // Send the message to the slave
  int result = Wire.endTransmission();
  if (result != 0) {
  Serial.print("Error in I2C transmission. Error code: ");
  Serial.println(result);
  Serial.print("\nMessage sent with ID: ");
  Serial.print("    and data: ");
  Serial.print(message);
My slave:
#include <Wire.h>
#include <WiFiNINA.h>
char ssid[] = "Ey, das tut W-LAN";
char pass[] = "27aa25!82T3006479e6";
String Apikey = "DRFURNGZGF3PDKBJ";
String server = "api.thingspeak.com"; // Only specify the domain name
WiFiClient client;
String field="";
float messageData = 0.0f;
float messageData1 = 0.0f;
float messageData2 = 0.0f;
float messageData3 = 0.0f;
float messageID = 0.0f;
static unsigned long lastUpdateTime = 0;
unsigned long currentTime = 0;
int status = WL_IDLE_STATUS; // Declare wifi status variable
bool uploadingToServer = false;
static const int RXPin = 12, TXPin = 13;
SoftwareSerial megaSerial(RXPin, TXPin); // RX, TX
// Addresses for I2C communication
// Received message initialization
byte receivedArray[sizeof(float) * MESSAGE_COUNT];
float receivedMessage[MESSAGE_COUNT];
float receivedValue;
  connectToWiFi();
  Wire.begin(SLAVE_ADDR);
  Wire.onReceive(receiveEvent);
  Wire.onRequest(requestEvent);
  Serial.println("Slave setup complete");
void connectToWiFi() {
  // Attempt to connect to Wi-Fi
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WiFi...");
    status = WiFi.begin(ssid, pass);
    delay(5000);
  Serial.println("Connected to WiFi");
void connectToThingSpeak() {
  if (client.connect(server.c_str(), 80)) {
    Serial.println("Connected to ThingSpeak server");
    Serial.println("Connection to ThingSpeak server failed");
void receiveEvent() {
  Serial.println("\nMessage received");
  Wire.readBytes(receivedArray, sizeof(receivedArray));
  // Extract message ID
  memcpy(&messageID, receivedArray, sizeof(messageID));
  // Extract message data
  memcpy(&messageData, receivedArray + sizeof(messageID), sizeof(messageData));
  // Display or process the received message
  displayReceivedMessage(messageID, messageData);
  // currentTime = millis();
  // unsigned long interval = currentTime - lastUpdateTime;
void requestEvent() {
  Serial.print("Request received\n");
  String acknowledgementMessage = "slave received the message";
  Wire.write(acknowledgementMessage.c_str(), acknowledgementMessage.length());
void displayReceivedMessage(float messageID, float messageData) {
  // You can customize this part based on your requirements
  if (messageID == 0) {
    Serial.print("fused X: ");
    // field = "&field1=";
    messageData1=messageData;
  } else if (messageID == 1) {
    Serial.print("fused Y: ");
    // field = "&field2=";
    messageData2=messageData;
  } else if (messageID == 2) {
    Serial.print("Acceleration input: ");
    // field = "&field3=";
    messageData3=messageData;
  Serial.print(messageData);
  Serial.println(); // Add a newline for clarity
  if(status != WL_CONNECTED) {
  Serial.print("Wifi connection failed. Attempting to reconnect...");
  connectToWiFi();
  delay(5000);
  Serial.println("Connected to WiFi\n");
  // Create HTTP request
  float trialData = 100;
  String http_str = "GET /update?api_key=" + Apikey +
                  "&field1=" + String(messageData1) +
                  "&field2=" + String(messageData2) +
                  "&field3=" + String(messageData3) +
                  " HTTP/1.1\r\n";
http_str += "Host: " + server + "\r\n";
http_str += "Connection: close\r\n\r\n";
  // Connect to the ThingSpeak server
  connectToThingSpeak();
  // Make the HTTP request
  client.print(http_str);
  client.stop();
  delay(3000);
Placing two 10K resistors in parallel will give you 5K.
In you post #1, you have said that there are only MEGA, UNOWiFiRev2, and IMU devices; then, why does the sketch of post #7 contain so much codes relating to so many devices?
1. Connect only MEGA and UNOWiFiRev2 and chcek that Slave is found at address 0x09. You can do it by uploading the following Scanner Program.
#include<Wire.h>
byte busStatus;
  Wire.begin();
  for (int i2cAddress = 0x00; i2cAddress < 0x7F; i2cAddress++)
    Wire.beginTransmission(i2cAddress);
    busStatus = Wire.endTransmission();
    if (busStatus == 0x00)
      Serial.print("I2C Device found at address: 0x");
      Serial.println(i2cAddress, HEX);
      Serial.print("I2C Device not found at address: 0x");
2. Connect your IMU device (if it isan I2C device) with the I2C Bus and run the Scanner program. Check the Slave Address from the output of Serial Monitor.
3. Acquire signal from IMU and show on Serial Monitor.
4. Use I2C bus and send the IMU signal to the Serial Monitor of UNOWiFiRev2.
There is also a driver connected, so I'm also remapping the PWM signals for the motors that I receive from the receiver but they are not relevant. There were also other sensors connected earlier but they are commented out in the loop as seen in the post that I shared. These are completely irrelevant.
Thank you for your suggestion. However, that's already what I have been trying to do, and the problem is precisely there. When I connect both the IMU and the slave Arduino (Arduino Uno Wifi rev2) I2C bus stops and the slave doesn't receive any messages from the master.
Follow the steps of post #9 and please tell where you are failing.
Post your own written sketches to send 13.75 and 34.58 to the Serial Monitor of UNOWiFiRev2 over the I2C Bus.
You may follow post #26 of this link.
