I2C Does not run on ATtiny85 to Arduino Mega
I am sending "hello " from the Attiny85 when requested by the Arduino Mega (Master).
Only getting: "????`" which translates to 255 255 255 255 96. There is obviously something going wrong with the protocol. Tiny: Using TinyWireS (newer version of github which includes TinyWireS.onRequest). Checked Connections:
5V
SDA (MEGA 20/Tiny 5)
SCL (MEGA 21/Tiny 7)
GND
Theres also an I2C LCD hooked up in the circuit, but it should not matter (I tried multiple different adresses of Tiny)
I burned the internal 8mhz Bootloader.
Master:
#include <Wire.h>
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  Wire.requestFrom(0x4, 6);    // request 6 bytes from slave device #8
  while (Wire.available()) { // slave may send less than requested
    //char c = Wire.read(); // receive a byte as character
    Serial.println(Wire.read());         // print the character
Slave:
#define I2C_SLAVE_ADDRESS 0x4 // the 7-bit address (remember to change this when adapting this example)
// Get this from https://github.com/rambo/TinyWire
#include <TinyWireS.h>
void requestEvent()
    TinyWireS.send("hello ");
    TinyWireS.begin(I2C_SLAVE_ADDRESS);
    TinyWireS.onRequest(requestEvent);
    TinyWireS_stop_check();
Thanks for your help in advance
No worries, it works!
