I2C, EEPROM communication problem
Hi.
I can’t read and write to the eeprom 24C16 using Arduino Uno.
I decided to investigate. At the beginning, I checked connection - it is OK. Pins 1-4, 7 to ground, pin 5 to A4, pin 6 to A5, pin 8 to 3,3V
Then, I tried to run I2C scanner from Gammon Forum : Electronics : Microprocessors : I2C - Two-Wire Peripheral Interface - for Arduino
// I2C Scanner
// Written by Nick Gammon
// Date: 20th April 2011
#include <Wire.h>
  Serial.begin (9600);
  // Leonardo: wait for serial port to connect
  while (!Serial)
  Serial.println ();
  Serial.println ("I2C scanner. Scanning ...");
  byte count = 0;
  Wire.begin();
  for (byte i = 1; i < 120; i++)
    Wire.beginTransmission (i);
    if (Wire.endTransmission () == 0)
      Serial.print ("Found address: ");
      Serial.print (i, DEC);
      Serial.print (" (0x");
      Serial.print (i, HEX);
      Serial.println (")");
      count++;
      delay (1);  // maybe unneeded?
      } // end of good response
  } // end of for loop
  Serial.println ("Done.");
  Serial.print ("Found ");
  Serial.print (count, DEC);
  Serial.println (" device(s).");
}  // end of setup
void loop() {}
I was surpised, because the result was:
Found address: 80 (0x50)
Found address: 81 (0x51)
Found address: 82 (0x52)
Found address: 83 (0x53)
Found address: 84 (0x54)
Found address: 85 (0x55)
Found address: 86 (0x56)
Found address: 87 (0x57)
Done.
Found 8 device(s).
Why? I connected only one device at address 0x50.
Do you guys have any idea what’s going wrong?
Thanks for your help.
If your device works as described in the FutureLec datasheet (http://www.futurlec.com/Memory/24C16SMD.shtml), this info on page 9 should help.
The 16K does not use any device address bits but instead the 3 bits are used for memory page addressing. These page addressing bits on the 4K, 8K and 16K devices should be considered the most significant bits of the data word address which follows. The A0, A1 and A2 pins are no connect.
Since the 3 bits are used to address memory pages, the chip will respond to any address of the form 0101xxx, which is why the scanner gets responses from 0x50 to 0x57.
Pete
Pepe,
you have rigth! I was blind. There is another addressing method.
Thank you a lot :)
