Hi everyone.
In the past i've been able to page-write to my eeprom and had no problems. I haven't had much need for writing as i've been using the eeprom as a security-key for a project.
Now when i go to write it fails and appears to be only succesfully writing 2 bytes/addresses
Any pointers would be great as i'm bewildered as to why it no longer works. Cheers.
#include <Wire.h>
#define DEV_ADDR 0x50
const char* HASH = "SPAM";
void i2c_eeprom_write_page( int deviceaddress, unsigned int eeaddresspage, byte* data, byte length ) {
Wire.beginTransmission(deviceaddress);
Wire.send((int)(eeaddresspage >> 8)); // MSB
Wire.send((int)(eeaddresspage & 0xFF)); // LSB
byte c;
for ( c = 0; c < length; c++)
Wire.send(data[c]);
Wire.endTransmission();
byte i2c_eeprom_read_byte( int deviceaddress, unsigned int eeaddress ) {
byte rdata = 0xFF;
Wire.send((int)(eeaddress >> 8)); // MSB
Wire.send((int)(eeaddress & 0xFF)); // LSB
Wire.requestFrom(deviceaddress,1);
if (Wire.available()) rdata = Wire.receive();
return rdata;
void write_hash(){
i2c_eeprom_write_page(DEV_ADDR, 0, (byte *)HASH, sizeof(HASH));
delay(100);
boolean check_hash(){
// checks to see if the hash n the eeprom matches the constant
static int addr = 0;
byte b = i2c_eeprom_read_byte(DEV_ADDR, addr);
while (b != 0){
if (b != HASH[addr])
return false;
addr++;
return true;
void print_hash(){
int addr = 0;
while (b != 0){
Serial.print((char)b);
addr++;
Wire.begin();
write_hash();
if (check_hash() == false){
Serial.println("BAD");
else{
Serial.println("ALL GOOD");
print_hash();
delay(2000);
