I2C EEPROM Library
Hi all,
After using internal eeprom of Arduino for a long time i thought of creating the similar type of library for external i2c eeproms.
So, I'm writing library for Atmel's I2C EEPROMS
Im also trying to overload subscripting operator[] to use a eeprom memory as array.
Any suggestion, guidance or help is welcomed.
Github link: https://github.com/cvmanjoo/AT24Cxx
cvmanjoo: Hi all,
Please, i need so much a command like EEPROM.get and EEPROM.put from the EEPROM.h library. Can you help me?
alejlle: Please, i need so much a command like EEPROM.get and EEPROM.put from the EEPROM.h library. Can you help me?
If this is a new problem, then create your own thread to ask your question. From the information given, I don't know how to help you. Are you having problems accessing GitHub? Can you download and test cvmanjoo's library from there? What does it do on your system? What would you like it to do?
