Hello all, I trying to control 16 LED's using SFE PCF8575c. I was able to test the chip using this example PCF8575 Demo - YouTube in which the LEDs are turned HIGH/LOW in sequence from LSB to MSB. I wired the 8575c breakout board as shown in the example
however the LEDs are all very very dim. I can see them flickering so I know the code and wiring works. I believe the issue is the chip
PCF8575 in source mode can't provide enough current.
and my wiring is in
"sink" mode (5v -> LED -> PCF8575 pin)
. What can I do to provide more current to the LEDs. I read somewhere perhaps a PNP transistor. I also tried putting a 330ohm resistor on each LED pin (i.e 8575 i/o pins) but that did little to help. Any ideas?
From the datasheet, looks like the part really only sinks current, not sources it.
I would say you'd want to send a 0 to the pin that you want to turn on, with resistor from 5V to anode, and cathode to the pin.
Thanks CrossRoads, I'll give that a try. Just to be clear, The part I'm using SparkFun I2C Expander Breakout - PCF8575 - BOB-08130 - SparkFun Electronics is the PCF8575c http://www.ti.com/lit/ds/symlink/pcf8575c.pdf which as I understand is slightly different from the 8575 used in the demo and the datasheet you mentioned.
- Quasi output: upper transistor is on for half
a clock cycle and then held up by a weak
current source (25-mA sink)
Quasi Output (Weak Current Source)
PCF8575/C 16-bit with Interrupt
Spec'ed the same:
P00, P-port input/output. Open-drain design structure. Connect to VCC through a pullup resistor.
So Vcc to Resistor to LED Anode, Cathode to Pxx. Low = LED on.
