Is there an obvious reason why all i2c values could suddenly start reporting max values?
I am using an Adafruit M0 feather. Attached to the M0 is a temperature sensor, RGB sensor, and accelerometer, all connected to the i2C bus.
Everything works perfectly as expected for about 7 days or so, then all the sensor values start reading (what appears to be) their max possible value.
For example, the temperature and humidity values are a float
. After about 7-ish days, the read values will become 2147484.0
, instead of 22.1
or 44.5
etc.
Here is the read humidity function:
float read_humidity(void)
RunningMedian samples = RunningMedian(NUM_READINGS);
//Read the sensor NUM_READINGS times with READING_DELAY between each reading
for (int i = 0; i < NUM_READINGS; i++)
float hum = (sensor.readHumidity()+2.5); //add calibration value
samples.add(hum);
delay(READING_DELAY);
#ifdef DEBUG
Serial.print("Humidity: ");
Serial.println(samples.getMedian());
#endif
float val = ((int)(1000*samples.getMedian()))/1000.0; //truncates to 3 decimal points
return val; //Get the median value and return it
My first thought was maybe there was some type of memory leak. I found this library for reporting the amount of free dynamic memory, and used it, but found that this was not the case, as the value remained constant for several days:
#include <MemoryFree.h>;
#ifdef __arm__
// should use uinstd.h to define sbrk but Due causes a conflict
extern "C" char* sbrk(int incr);
#else // __ARM__
extern char *__brkval;
#endif // __arm__
Then added Serial.println(freeMemory());
the main loop.
I am stumped. It is unfortunate that it takes so long for this to occur. It makes debugging very difficult...
I found that (this may be obvious) that when I unplug any of the sensors, the values for that sensor will become the max values until I plug the sensor back in.
So after the 7 day failure event, it is almost as if the entire i2c bus becomes disconnected.
Full code below:
#ifdef __arm__
#else // __ARM__
#endif // __arm__
//=======================Compile Options+============================
#define SERIAL_OUTPUT //Comment to turn off serial output and save memory
//===========================Libraries===============================
#include <Wire.h>
#include <SPI.h>
#include <RH_RF95.h> //Radio
#include <RHReliableDatagram.h> //Radio manager
#include <Adafruit_MPU6050.h> //acclerometer
#include <Adafruit_Sensor.h>
#include "Adafruit_Si7021.h" //Temp/Humidity
#include <RunningMedian.h>
#include <Adafruit_NeoPixel.h> //RGB LED
#include "SparkFunISL29125.h" //RGB Light sensor
#ifdef __AVR__
#include <avr/power.h>
#endif
//==============================Pins=================================
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 3
const int pausePin = 0;
const int ledPin = 5; //RGB LED
//============================Constants==============================
#define NODE_ID 1 //This Node's unique ID
#define SERVER_ID 41 //The server this node should be talking to
#define RF95_FREQ 915.0 // Frequency must match RX's freq
#define NUM_READINGS 9 //Number of readings for each sensor. Median is taken from readings. Must be an odd number
#define NUM_READINGS_accel 695
#define READING_DELAY 10 //Delay in ms between each of the NUM_READINGS readings
#define LED_BRIGHTNESS 3 //Global LED brightness 0-10.
const uint16_t tx_hb_time = 1500*(NODE_ID*0.750); //Tx heartbeat time in milliseconds
//Colours
enum colours
OFF = 0,
RED,
GREEN,
YELLOW,
ORANGE,
BLUE,
NUM_COLOURS
//=============================Objects===============================
//The data packet being sent by this node
typedef struct NodePacket
int nodeID;
int paused;
float accelX_amp;
float accelX_freq;
float accelY_amp;
float accelY_freq;
float accelZ_amp;
float accelZ_freq;
int light_R;
int light_G;
int light_B;
float temp;
float hum;
//The data packet being received from the server
typedef struct ServerPacket
int nodeID;
int paused;
int pauseRequested;
int startRequested;
Adafruit_MPU6050 mpu;
Adafruit_Sensor *mpu_accel;
Adafruit_Si7021 sensor = Adafruit_Si7021();
RH_RF95 rf95(RFM95_CS, RFM95_INT);
RHDatagram manager(rf95, NODE_ID);
Adafruit_NeoPixel pixel = Adafruit_NeoPixel(1, 5, NEO_GRB + NEO_KHZ800);
SFE_ISL29125 RGB_sensor;
ServerPacket serverPacket;
NodePacket nodePacket;
//=========================Global Variables==========================
int lastTxTime = 0; //last time in millis a transmission occured
int paused = 0; //paused status
int buttonPressedFlag = 0;
int buttonState = 0;
//===============================Setup===============================
init_structures();
init_LED();
init_radio();
init_pauseButton();
init_accelerometer();
init_lightSensor();
set_LED(GREEN, LED_BRIGHTNESS);
//===============================Loop================================
transmit();
delay(2000);
read_sensors();
/* read_sensors
@brief Reads all sensors, checks thresholds,
and builds the radio packet.
@param None
@return None
void read_sensors(void)
float accelVals[3]; //X, Y, Z
int lightVals[3]; //R, G, B
#ifdef SERIAL_OUTPUT
Serial.println("Reading Sensors");
#endif
//Build packet
nodePacket.nodeID = NODE_ID;
//Read Temperature and check threshold
nodePacket.temp = read_temp();
//Read Humidity and check threshold
nodePacket.hum = read_humidity();
//Read Accelerometer and check threshold
read_accel(accelVals);
nodePacket.accelX_amp = accelVals[0];
nodePacket.accelY_amp = accelVals[1];
nodePacket.accelZ_amp = accelVals[2];
nodePacket.accelX_freq = 0; //Placeholder
nodePacket.accelY_freq = 0; //Placeholder
nodePacket.accelZ_freq = 0; //Placeholder
//Read light and check threshold
read_light(lightVals);
nodePacket.light_R = lightVals[0];
nodePacket.light_G = lightVals[1];
nodePacket.light_B = lightVals[2];
//read pause button
buttonState = digitalRead(pausePin);
if (buttonState == LOW && buttonPressedFlag == 0)
buttonPressedFlag = 1;
if (paused == 0)
paused = 1;
}else{
paused = 0;
delay(500);//debounce
if (buttonState == HIGH && buttonPressedFlag == 1)
if(paused)
set_LED(YELLOW, LED_BRIGHTNESS);
nodePacket.paused = paused; //update the message packet
/* init_accelerometer
@brief Initializes the accelerometer.
@param None
@return None
void init_accelerometer(void)
// Try to initialize!
if (!mpu.begin()) {
Serial.println("Failed to find MPU6050 chip");
while (1) {
delay(10);
mpu.setAccelerometerRange(MPU6050_RANGE_2_G);
mpu.setFilterBandwidth(MPU6050_BAND_44_HZ);
mpu_accel = mpu.getAccelerometerSensor();
delay(100);
/* init_radio
@brief Initializes all radio settings.
@param None
@return None
void init_radio(void)
pinMode(RFM95_RST, OUTPUT);
digitalWrite(RFM95_RST, HIGH);
// manual reset
digitalWrite(RFM95_RST, LOW);
delay(10);
delay(10);
while (!manager.init()) {
#ifdef DEBUG
Serial.println("Radio init failed");
#endif
while (1);
#ifdef DEBUG
Serial.println("Radio init passed");
#endif
// Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
if (!rf95.setFrequency(RF95_FREQ)) {
#ifdef DEBUG
Serial.println("setFrequency failed");
#endif
while (1);
#ifdef DEBUG
Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
#endif
// Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
// The default transmitter power is 13dBm, using PA_BOOST.
// If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
// you can set transmitter powers from 5 to 23 dBm:
rf95.setTxPower(23, false);
/* transmit
@brief Transmits nodePacket to SERVER_ID until a reply from SERVER_ID
is received or num_tx_attempts is exceeded. Reply from SERVER_ID
contains thresholds that update local thresholds if the reply is valid.
@param None
@return None
void transmit(void)
uint8_t len = sizeof(serverPacket);
uint8_t fromAddress;
Serial.println("\nTransmitting: ");
Serial.print("Node ID: \t");
Serial.println(nodePacket.nodeID);
Serial.print("Paused: \t");
Serial.println(nodePacket.paused);
Serial.print("X Accel: \t");
Serial.println(nodePacket.accelX_amp);
Serial.print("Y Accel: \t");
Serial.println(nodePacket.accelY_amp);
Serial.print("Z Accel: \t");
Serial.println(nodePacket.accelZ_amp);
Serial.print("R Light: \t");
Serial.println(nodePacket.light_R);
Serial.print("G Light: \t");
Serial.println(nodePacket.light_G);
Serial.print("B Light: \t");
Serial.println(nodePacket.light_B);
Serial.print("Temperature: \t");
Serial.println(nodePacket.temp);
Serial.print("Humidity: \t");
Serial.println(nodePacket.hum);
#endif
if(!manager.sendto((uint8_t *)&nodePacket, sizeof(nodePacket), SERVER_ID))
Serial.println("Transmit failed");
#endif
rf95.waitPacketSent();
// Now wait for a reply
Serial.println("\nWaiting for reply...");
#endif
if (rf95.waitAvailableTimeout(500))
// Should be a reply message for us now
if (manager.recvfrom((uint8_t *)&serverPacket, &len, &fromAddress))
if(fromAddress != SERVER_ID)
Serial.println("Rcvd from wrong server");
#endif
else if(serverPacket.nodeID != NODE_ID)
Serial.println("Rcvd wrong msg");
#endif
Serial.println("\nReply valid");
Serial.println("Received: ");
Serial.print("Node ID: \t\t");
Serial.println(serverPacket.nodeID);
Serial.print("Paused: \t\t");
Serial.println(serverPacket.paused);
Serial.print("Pause req: \t\t");
Serial.println(serverPacket.pauseRequested);
Serial.print("start req: \t\t");
Serial.println(serverPacket.startRequested);
#endif
updateThresholds();
Serial.println("Receive failed");
#endif
Serial.println("No reply");
#endif
// nodePacket.context = NO_TX; //Reset context
lastTxTime = millis();
/* read_temp
@brief Reads temperature from sensor and returns float.
@param None
@return float temperature
float read_temp(void)
float temp = (sensor.readTemperature()-0.9); // minus calibration value
samples.add(temp);
#ifdef DEBUG
Serial.print("Temp: ");
#endif
/* read_humidity
@brief Reads humidity from sensor and returns float.
@param None
@return float humidity
samples.add(hum);
#ifdef DEBUG
#endif
/* read_accel
@brief Reads accelerations from sensor and updates accelVals[].
@param float accelVals[]
@return None
void read_accel(float accelVals[])
RunningMedian x_samples = RunningMedian(NUM_READINGS_accel);
RunningMedian y_samples = RunningMedian(NUM_READINGS_accel);
RunningMedian z_samples = RunningMedian(NUM_READINGS_accel);
for (int i = 0; i < NUM_READINGS_accel; i++)
sensors_event_t accel;
mpu_accel->getEvent(&accel);
x_samples.add(accel.acceleration.x);
y_samples.add(accel.acceleration.y);
z_samples.add(accel.acceleration.z);
float valx = ((int)(1000*x_samples.getHighest()))/1000.0;
float valy = ((int)(1000*y_samples.getHighest()))/1000.0;
float valz = ((int)(1000*z_samples.getHighest()))/1000.0;
accelVals[0] = (valx);
accelVals[1] = (valy);
accelVals[2] = (valz);
/* read_light
@brief Reads light values from sensor and updates lightVals[].
@param float lightVals[]
@return None
void read_light(int lightVals[])
RunningMedian r_samples = RunningMedian(NUM_READINGS);
RunningMedian g_samples = RunningMedian(NUM_READINGS);
RunningMedian b_samples = RunningMedian(NUM_READINGS);
r_samples.add(RGB_sensor.readRed());
g_samples.add(RGB_sensor.readGreen());
b_samples.add(RGB_sensor.readBlue());
float valr = ((int)(1000*r_samples.getHighest()))/1000.0;
float valg = ((int)(1000*g_samples.getHighest()))/1000.0;
float valb = ((int)(1000*b_samples.getHighest()))/1000.0;
lightVals[0] = valr;
lightVals[1] = valg;
lightVals[2] = valb;
/* init_LED
@brief Initializes the RGB NeoPixel LED.
@param None
@return None
void init_LED(void)
pixel.begin();
set_LED(RED, LED_BRIGHTNESS);
/* set_LED
@brief Sets the RGB LED to a predefined colour.
@param uint8_t colour. Colour value from enum colours
@param uint8_t brightness. Brightness value from 1-10
@return None
void set_LED(uint8_t colour, uint8_t brightness)
uint8_t red = 0;
uint8_t green = 0;
uint8_t blue = 0;
uint8_t divider = 11 - brightness;
divider = constrain(divider, 1, 10);
if(colour == OFF)
divider = 1;
switch (colour)
case OFF:
red = 0;
green = 0;
blue = 0;
case RED:
red = 255;
green = 0;
blue = 0;
case GREEN:
red = 0;
green = 255;
blue = 0;
case YELLOW:
red = 255;
green = 240;
blue = 0;
case ORANGE:
red = 255;
green = 145;
blue = 0;
case BLUE:
red = 0;
green = 0;
blue = 255;
default:
red = 0;
green = 0;
blue = 0;
pixel.setPixelColor(0, pixel.Color(red/divider, green/divider, blue/divider));
pixel.show();
#ifdef DEBUG
Serial.print("LED: ");
Serial.println(colour);
#endif
/* init_lightSensor
@brief Initializes the RGB light sensor.
@param None
@return None
void init_lightSensor(void)
RGB_sensor.init();
/* init_pauseButton
@brief Initializes the pause button pin.
@param None
@return None
void init_pauseButton(void)
pinMode(pausePin, INPUT_PULLUP);
/* init_ISR
@brief Initializes the interrupt service routine.
@param None
@return None
//void init_ISR(void) {
// pinMode(interruptPin1, INPUT_PULLUP);
// attachInterrupt(digitalPinToInterrupt(interruptPin1), ISR_buttonPressed, LOW);
/* init_structures
@brief Initializes the nodePacket values.
@param None
@return None
void init_structures()
nodePacket.paused = 0;
nodePacket.accelX_amp = 0;
nodePacket.accelY_amp = 0;
nodePacket.accelZ_amp = 0;
nodePacket.light_R = 0;
nodePacket.light_G = 0;
nodePacket.light_B = 0 ;
nodePacket.temp = 0 ;
nodePacket.hum = 0;
/* updateThresholds
@brief Updates local thresholds from serverPacket (received).
@param None
@return None
void updateThresholds(void)
Serial.println("Updating Thresholds");
#endif
Serial.print("node paused: \t\t");
Serial.println(paused);
Serial.print("server paused: \t\t");
paused = serverPacket.paused;
