I2C, Feather M0 and Honeywell HSC pressure sensor
First time posting, so I hope this in the right place and I have included all the detail you need.
I think trying to attach 3 files is making this post too large, some files mentioned here may be attached to a comment, below.
I am trying to read and log a pressure measurement to an SD card using Arduino.
My first purchases were Arduino Uno and a Honeywell HSCMAND015PA5A2 pressure sensor.
The datasheet for these sensors is here: Safety and Productivity Solutions | Honeywell
  • I connected up the pressure sensor - picture of set up in attached pdf.
  • I followed these instructions, downloading the library on that page: Arduino Playground - HoneywellTruStabilitySSC-HSCPressureSensors
  • I created a sketch based on Option #2 in the above link, controlling the sensor from the serial monitor. I had to make a couple of modifications to get it to work, here’s my code:
#include <Wire.h>
#include <SSC.h>
//create an SSC sensor with I2C address 0x28 and power pin 8.
//If you have connected the SSC sensor to another pin, change this number!
//If you are using something other than model HSCDANN015PA2A5 check that the address is 0x28 (manual)
SSC ssc(0x28, 8);
void setup() {    // put your setup code here, to run once:
//while (!Serial); is needed for the Feather board, unless using the 'void wait for serial' loop, above
//while (!Serial);
Wire.begin();
//set min and max reading and pressure values, see datasheet for eqn
ssc.setMinRaw(1638);        // output at minimum calibrated pressure (counts)
ssc.setMaxRaw(14745);    //output at maximum calibrated pressure (counts)
ssc.setMinPressure(0.00); // min value of pressure range (ours 0-15 PSI gage)
ssc.setMaxPressure(15.00); // max value of pressure range (ours 0-15 PSI gage)
//start your sensor
Serial.println("the sensor is starting");
ssc.start();
Serial.print("the starting pressure is:");
Serial.println(ssc.pressure());     //returns the starting pressure)
Serial.println("end of starting section");
while(Serial.available()) {
  ssc.commandRequest(Serial);
delay(100);
This seems to work, the first output of ssc.pressure is '73.13', but after a ‘u’ for update I get a sensible pressure, 14.8, which can be changed if I raise or lower the ambient pressure.
Then I wanted to see if I could get this set up to measure repeatedly, so I used Option #1 from the Arduino link, above. Again, a couple of modifications later I had this:
#include <Wire.h>
#include <SSC.h>
SSC ssc(0x28, 8);
  Wire.begin();
ssc.setMaxRaw(14746);    //output at maximum calibrated pressure (counts)
ssc.setMinPressure(0); // min value of pressure range (ours 0-150 PSI gage)
ssc.setMaxPressure(15); // max value of pressure range (ours 0-150 PSI gage)
//start your sensor
Serial.println("the sensor is starting");  // this prints in the serial print "the sensor is starting() and two tabs" (\t = tab)
ssc.start();  // the 'println' bit does a carriage return
//update pressure/temperature
Serial.println("updating...");
ssc.update();
Serial.print("pressure is: "); //returns the new pressure
delay(5000);
And again, this works fine.
I have also then gone on to get this to save to an SD card and successfully used it for a couple of multi-hour experiments, so far so good.
My problem is that I wanted to switch to a smaller board. I have an Adafruit Feather MO Proto. These, I believe, have 3.3 not 5V logic so I purchased a new pressure sensor:
HSCSANN015PA2A3
(the datasheet I linked to above covers this as well).
Again, photo of set up in attached pdf.
I followed the step-by-step instructions here - Overview | Adafruit Feather M0 Basic Proto | Adafruit Learning System – to prepare the Arduino IDE for use with this feather board.
Then I loaded my first sketch. The only changes I made where the “while Serial” bit, which I got from the adafruit link and to change the pin number:
#include <Wire.h>
#include <SSC.h>
SSC ssc(0x28, 6);
while (!Serial);
Wire.begin();
//start your sensor
ssc.start();
delay(100);
My verbose output is attached as a text file.
The serial port, when opened, immediately prints:
the starting pressure is:-1.87
These are the commands available:
• '1': start the sensor
• '0': stop the sensor
• 'a': return the I2C address
• 'q': return the power pin
• 'u': update pressure / temperature
• 'p': return pressure (as a float)
• 't': return temperature (as a float)
• 'b': return min pressure (float)
• 'c': return max pressure (float)
• 'd': return min reading (raw: uint16_t)
• 'e': return max reading (raw: uint16_t)
• 'B': set min pressure (float)
• 'C': set max pressure (float)
• 'D': set min reading (raw: uint16_t)
• 'E': set max reading (raw: uint16_t)
‘p’ doesn’t change, even if preceded with a ‘1’ or a ‘0’ and it freezes the entire serial monitor window if type ‘u’ (best case scenario, serial monitor won’t let me type anything else and I can close it, but sometimes it ‘freezes’ so bad I have to ctrl+alt+delete.
I can replicate this set up on the Arduino Uno by getting my SDA and SCL cables the wrong way round, but I’ve tested that.
Other things I’ve tried:
• Using a different pin instead of pin 6
• Rebooting the feather and trying again
• Using a different breadboard
• Checking soldering on the feather
• Trying with and without pull up resistors
• Trying this library (GitHub - rodan/honeywell_hsc_ssc_i2c: avr library for honeywell hsc and ssc series pressure sensors (i2c version)) – still just reports -1.87 for pressure
• Accepting I'm a beginner and could have screwed something up royally, uninstalled Arduino (completely) and reinstalled it and the SAMD drivers and SSC library, etc.
It says here - Adapting Sketches to M0 & M4 | Adafruit Feather M0 Basic Proto | Adafruit Learning System - that pin outputs/pullups are different for the M0 – perhaps I need to change something in my SSC library .h and .cpp files?
I have also read online the Feather M0 might have trouble with the standard wire library for I2C, but I’m not sure what I would do about that, I don’t want to fiddle with standard libraries and I downloaded the SAMD packages as per the adafruit instructions, so I would hope this is OK.
This has been several days of tests now…I’m a beginner so I’m sure it’s something simple/stupid I’ve overlooked.
Any suggestions gratefully received!
I'm wondering at this point whether to give up on the M0 and try and find a feather board that is more similar to the Uno... (I've got a feather wing logger, and they're the perfect shape so I want to carry on down this route if I can)
Thanks in advance.
HSC-tests-verbose.txt (16.3 KB)
set ups.pdf (271 KB)
The picture isn't telling it really but I think you misinterpreted what a pull-up is. It looks like you have resistors from the I2C pins of the M0 to the corresponding pins on the sensor. And you connected the I2C pins both directly to 3V3. If the MCU sends anything this makes a great short circuit. This might have damaged the I2C pins of the MCU.
Try connecting the I2C lines correctly. So SDA of the M0 goes to SDA of the sensor and SCL the same way. Now you put a resistor (2k2) from SDA to 3V3 and a seconds resistor from SCL to 3V3. These are the pull-ups. Also provide 3V3 and GND to the corresponding pins of the sensor.
Try again your sketch.
What pylon says.
@pandemma, you mean the "HSCMAND015PA2A5" ? but you wrote "HSCMAND015PA5A2".
Extra info:
HSC M AN D 015PA 2 A 5 = SMT, Single axial port, dry gasses, diagnostics, 15 psi absolute, I2C 0x28, 10-90% Vcc, 5V.
HSC S AN N 015PA 2 A 3 = SIP, Single axial port, dry gasses, no diagnostics, 15 psi absolute, I2C 0x28, 10-90% Vcc, 3.3V.
I suppose that an analog output is ratiometric, but via the I2C interface it is probably an absolute value. But I'm not sure about that.
Do you want to know the baromic value ? We all use the BMP180, BMP280, BME280 series from Bosch.
