I2C headphone amp no output
I’m working on an device, which outputs sounds over headphones. I designed a custom PCB, the sound section consists of an Atmega 328p and the Texas Instruments TPA6130A2 headphone amp. The Atmega runs Mozzi with dual-PWM-output.
My issue is, that there is no output on the headphone amp, here the code I used for testing so far:
#include <MozziGuts.h>             // Mozzi main library
#include <Oscil.h>                 // Mozzi template for an oscillator
#include <tables/sin2048_int8.h>   // Mozzi wavetable holding a sine wave
#include <twi_nonblock.h>          // Mozzi non-blocking I2C Library
// --- Mozzi definitions ---
Oscil <2048, AUDIO_RATE> aSin(SIN2048_DATA); // defines an sine tone oscillator with the sin2048 wavetable. Structure: Oscil <table_size, update_rate> name(table_data);
#define CONTROL_RATE 64 // number of control updates, only powers of 2
int audioFrequency = 440;
// --- Audio Amplifier I2C definitions ---
#define AMP_ADDRESS 0x60       // TPA6130A2 device address
// Register 1: HP_EN_L, HP_EN_R, Mode[1], Mode[0], Reserved, Reserved, Reserved, Thermal, SWS
#define AMP_REG1 0x1           // TPA6130A2 register 1 address
#define AMP_REG1_SETUP 0xc0    // default configuration: 11000000 - both channels enabled
// Register 2: Mute_L, Mute_R, Volume[5-0]
#define AMP_REG2 0x2           // TPA6130A2 register 2 address
#define AMP_REG2_SETUP 0x34        // default configuration: 00110100 - both channels on –0.3 dB Gain
  startMozzi(CONTROL_RATE);
  initialize_twi_nonblock(); // initialize I2C library and join I2C-Bus
  initializeAmp();
void initializeAmp() {
    amp_writeTo(AMP_REG1, AMP_REG1_SETUP);
    amp_writeTo(AMP_REG2, AMP_REG2_SETUP);
void updateControl(){
  aSin.setFreq(audioFrequency);
int updateAudio(){
  return aSin.next();
void amp_writeTo(byte address, byte val) {
  twowire_beginTransmission(AMP_ADDRESS);  // start transmission to device
  twowire_send( address );                 // send register address
  twowire_send( val );                     // send value to write
  twowire_endTransmission();               // end transmission
  audioHook();
I don’t have much experience with I2C communication, so maybe someone experienced could see the problem.
Thanks for help
m9898
EDIT: Sorry for cross-posting, but as I got no more replies here, I opened a second thread in the EEVblog-Forum: http://www.eevblog.com/forum/projects/i2c-headphone-amp-no-output/
Got a schematic?
And links to these?
Thanks for your reply. I don't have the schematic at hand right now. But it's easy: The atmega with dual-PWM output as described on the librarys website connected to the TPA6130A2 used as shown in the typical application diagram. And also the two I2C-lines with 4,7K pullups between them.
The source of the library is here: https://github.com/sensorium/Mozzi
And here is the relevant part of the schematics:
