I2C help needed
I am tring to understand and learn I2C better and in doing so have come accross the following question.
I am using part of the I2C example code on the Arduino Learning website for the WIre Library SFR_Ranger reader.
My particular I2C device has a 14-bit reolution and the data is stored in Registers 254 and 255. In 255 the bits 6 and 7 are not used, hence the 14 bits.
Question 1)
I am confused about why I read register 255 in the code with 2 bytes, I would have thought it should read register 254 first but that just gives garbage.
Question 2)
In the statement reading = reading << 6;    // shift high byte to be high 8 bits I read the correct 14 bit data with range of 0 - 16383.
If I change the 6 to an 8 as in original code, which i understand is 16 bit, the output range is 0 - 65535. While I assume this is just the 14 bit data interpolated into the 16 bit range so resolution would not be any greater, My question is how does it do this? It is now reading 8 bits from each register but 2 of the bits are unused in the first register.
The answer is probably staring me in the face but i dont get it.
here is the working code.
#include <Wire.h>
  Wire.begin();                // join i2c bus (address optional for master)
  Serial.begin(9600);          // start serial communication at 9600bps
unsigned int reading = 0;
 Wire.beginTransmission(66); // transmit to device #112
 Wire.write(byte(255));      // sets register pointer to echo #1 register (0x02)
 Wire.endTransmission();      // stop transmitting
  // step 4: request reading from sensor
  Wire.requestFrom(66, 2);    // request 2 bytes from slave device #112
  // step 5: receive reading from sensor
  if(2 <= Wire.available())    // if two bytes were received
    reading = Wire.read();  // receive high byte (overwrites previous reading)
    reading |= Wire.read(); // receive low byte as lower 8 bits
    Serial.println(reading);   // print the reading
  delay(300);                  // wait a bit since people have to read the output :)
A lot depends on the specifications of your device. Not all 14-bit resolution device are exactly alike. Can you point to the datasheet?
Hi John Thank you. http://www.ams.com/eng/Products/Magnetic-Position-Sensors/Magnetic-Rotary-Position-Sensors/AS5048B
btw, the I2C table is on pg21. The device also does SPI and PWM but the I2C information is very minimal.
Is it 66 or 112? The datasheet says that some of the I2C address bits are set by OTP so without actually getting it to respond you don't know what any individual device's address will be. Have you run an I2C bus scanner to see what responds? Run Nick's I2C scanner sketch which is near the bottom of this page http://www.gammon.com.au/forum/?id=10896
Pete
The datasheet doesn’t show the ability to do sequential reads. I would read the two registers separately:
    Wire.write(byte(254));      // sets register pointer to angle MSB
    Wire.requestFrom(66, 1);    // request 2 bytes from slave device #112
    if(Wire.available())
    reading <<= 6;    // shift MSB to be bits 6-13.
    Wire.write(byte(255));      // sets register pointer to angle LSB
        reading |= (Wire.read() & 0x3F); // receive low six bits
Is it 66 or 112?
Sorry, the comments were from original code. It is 66 that can communicate with. I have the manual bits set to A1=0 and A2 = 1 so according to the data sheet the defalt address is 10000 plus A2 A1 which is 1000010 = 66 and this works. I tried the I2C scanner but it does not find any device.
The datasheet doesn't show the ability to do sequential reads. I would read the two registers separately:
When I try that code, it seems to be random data that doesnt change logically when I rotate the device. 3543 407 2826 2425 2930 2610 2482 2610 3183 1571 1630 990 1758 1306 656 716 2827 2186 767 53 3891 3699 3571 807 1058 801 736 601 538 730 794 602 538
Using my posted code I get good data smoothly changing as i rotate the device 14 74 76 75 220 579 801 1160 1473 1691 2005 2256 2427 2663 2832 3024 3251 3520 4038 4303 4624 4914 5220 5922 6707 7407 7946 8529 9568 10686 11401 12014 12632 12637 12640 12718 13130 13520 14093 14244 14463 14802 14697 14698 I am just trying to understand why I only get this result when reading register 255 with 2 bytes? How does it get the readings from 254 in there.
The scanner tries every possible valid address so if it doesn't find anything how can you be getting a valid response?
Pete
I really do not know, All i can tell you is that it says not found. If I try the scanner with an LCD I have i see it operates correctly and finds the LCD Address. On the data sheet is says you can program the address but it only allows 1 time. I have not done this as yet so is it possible that it will not answer an inquiry (Whatever the scanner is sending) but will respond to a write command if the correct default address is used?
I'm a bit confused about the relationship between the numbers 66 and 112.
Your explanation of which two bits are not used seems implausible. Are you sure it is the most
significant 2 bits of the low byte which are unused ?
You may need to be shifting the first byte you read by 8 bits, not 6 bits, if that is the case.
If you only shift the first byte you read by six bits, then the second byte you read will overwrite
the least significant two bits of the first byte, which is probably not what you intended.
I’d suggest printing the actual hex value of the two bytes which you read to the serial monitor
and examining them closely, to check.
If i do that then the output goes to 16-bit (0 - 65535) which is clearly incorrect.
As I said above, the 112 is part of the comments from the arduino code example, I changed the address to 66
So I gather you are getting valid readings, and your question is “why am I getting valid readings?”
I’ve used this device using SPI and you ask for address 0xFFFF and then read 2 bytes, which looks like what is happening for you.
Hi Nick. Yes exactly. At least it appears i am getting valid readings. I just dont understand that if the data is contained in 254 and 255, why it only works when I call 255? I am not calling 254 at all but it seems to be getting the data from it.
Here is the HEX output with the bits shifted 6
0, E
0, 34
1, 6C
3, C7
3, F8
5, 153
6, 1B6
9, 242
C, 312
F, 3DD
12, 483
15, 543
16, 5A1
17, 5D6
1A, 699
1B, 6F7
1F, 7C9
23, 8D4
25, 964
28, A29
2A, AA7
2D, B7C
33, CCC
35, D70
39, E46
3D, F4E
41, 1065
45, 1144
4A, 1292
4E, 139F
55, 1575
5E, 17BF
63, 18CA
6C, 1B06
72, 1C93
78, 1E2B
78, 1E2B
78, 1E17
82, 2083
8D, 2378
96, 259B
A1, 2844
AA, 2A82
B0, 2C00
B5, 2D58
BD, 2F40
C8, 322F
D4, 3518
E1, 386C
ED, 3B4A
F3, 3CD7
F4, 3D10
F4, 3D0E
F9, 3E4D
Here is the decimal output
0, 18
2, 130
8, 522
15, 975
24, 1582
34, 2237
45, 2936
58, 3723
72, 4640
89, 5730
98, 6315
112, 7223
128, 8231
132, 8470
132, 8471
139, 8936
153, 9849
170, 10894
181, 11597
190, 12190
200, 12846
215, 13766
225, 14435
228, 14642
233, 14968
240, 15399
247, 15836
251, 16116
255, 16347
with this code
#include <Wire.h>
int reading1 = 0;
 Wire.beginTransmission(66); // transmit to device #66
    Serial.print(reading);   // print the reading
    Serial.print(", ");
Their documentation is pretty obscure, and your results agree, as I say, with the way that the SPI interface works. This is my SPI code, and it reads two bytes:
// for parity checks
const unsigned int masks [16] = {
      0x01, 0x02, 0x04, 0x08,
      0x10, 0x20, 0x40, 0x80,
      0x100, 0x200, 0x400, 0x800,
      0x1000, 0x2000, 0x4000, 0x8000 };
unsigned int AS5048A::Transfer (const unsigned int command)
  byte hi, lo;
  SPI.setDataMode (SPI_MODE1);
  digitalWrite (chipSelect_, LOW);
  hi = SPI.transfer (highByte (command));
  lo = SPI.transfer (lowByte (command));
  digitalWrite (chipSelect_, HIGH);
  unsigned int result = makeWord (hi, lo);
  // calculate parity
  byte parity = 0;
  for (byte i = 0; i < 16; i++)
    if (result & masks [i])
      parity++;
  // even parity, so low-order bit should be zero
  if (parity & 1)
    parityFlag_ = true;
    errorFlag_ = false;  // we actually don't know the error flag state
    parityFlag_ = false;
    errorFlag_ = (result & EF) != 0;
  return result;
  } // end of AS5048A::Transfer
Thanks Nick. As usual you are such an asset to this forum. So it seems my output must be correct then. It sure seems correct as I rotate the magnet. Does your I2C Scanner find your device?
Lsnyman:
Thanks Nick.
Thanks! :slight_smile:
No, in my case it was configurecd as an SPI device (and soldered onto a board that I can’t change). I’m a little surprised that the scanner doesn’t find it, however if the figures are correct presumably it is there.
