I2C is different between MEGA and UNO?
One of the device is http://www.geekonfire.com/wiki/index.php?title=I2C_OLED_Panel(128x64)#Resources. It works on UNO and MEGA at 100kbps, but at 400kbps only works at MEGA.(I have tested it on MEGA2560,MEGA1280 and MEGA Olympic)
code in library:
//uint8_t twbrbackup = TWBR;
//TWBR = 12; // upgrade to 400KHz!
// TWBR = twbrbackup;
if I enable the above sentences, It doesn't work at UNO.
void GOFi2cOLED::display(void) {
  sendCommand(0x00 | 0x0);  // low col = 0
  sendCommand(0x10 | 0x0);  // hi col = 0
  sendCommand(0x40 | 0x0); // line #0
    // save I2C bitrate
    // I2C
    #if defined(ARDUINO) && ARDUINO >= 100
    for (uint16_t i=0; i<(128*64/8); i++)
      // send a bunch of data in one xmission
      Wire.beginTransmission(SlaveAddress);
      Wire.write(GOFi2cOLED_Data_Mode);            // data mode
      for (uint8_t x=0; x<16; x++)
        Wire.write(buffer[i]);
        i++;
      i--;
      Wire.endTransmission();
    #else
      Wire.send(GOFi2cOLED_Data_Mode);            // data mode
        Wire.send(buffer[i]);
        i++;
      i--;
    #endif
