I2C Laser Sensor - Pro Mini Connection Problem
Hello all,
I am trying to connect a distance sensor VL6180x to Arduino Pro Mini via I2C. Yesterday it was working without any problems, but today it refuses to work, even though I haven't changed anything. The sensor has a logic level shifter and pullup resistors onboard. I tested it with Arduino Uno and works perfectly again. However I can't get it to work with Pro Mini again. I am using the Wire library and the VL6180x library. Pins are A4-SDA, A5-SCL, VCC-VIN, GND-GND. Here is the code I am using. It is giving TIMEOUT all the time.
#include <Wire.h>
#include <VL6180X.h>
VL6180X sensor;
  Wire.begin();
  sensor.init();
  sensor.configureDefault();
  // Reduce range max convergence time and ALS integration
  // time to 30 ms and 50 ms, respectively, to allow 10 Hz
  // operation (as suggested by Table 6 ("Interleaved mode
  // limits (10 Hz operation)") in the datasheet).
  sensor.writeReg(VL6180X::SYSRANGE__MAX_CONVERGENCE_TIME, 30);
  sensor.writeReg16Bit(VL6180X::SYSALS__INTEGRATION_PERIOD, 50);
  sensor.setTimeout(500);
   // stop continuous mode if already active
  sensor.stopContinuous();
  // in case stopContinuous() triggered a single-shot
  // measurement, wait for it to complete
  delay(300);
  // start interleaved continuous mode with period of 100 ms
  sensor.startInterleavedContinuous(100);
  Serial.print("\tRange: ");
  Serial.println(sensor.readRangeContinuous());
  if (sensor.timeoutOccurred()) { Serial.println(" TIMEOUT"); }
Here is my serial monitor:
Range: 255
TIMEOUT
Range: 255
TIMEOUT
Range: 255
TIMEOUT
Range: 255
TIMEOUT
Range: 255
TIMEOUT
Range: 255
I suspect something is wrong with the A4 A5 pins of the Pro Mini, or a software problem within the Wire library. Any help wpuld be greatly appreciated.
Oh, by the way I am using FTDI232 USB to serial converter to program the arduino Pro mini.
