good day. Im using pro micro bords and want to run 16x2 i2c lcd. i ran i2c scanner and find the address as 0x27. so the controler see the lcd, but it does not display any thing. sda conected to pin 2 and scl to pin 3. changed contrast......does any one know wat i coukld be missing?
the code
#include <Wire.h>
#include <max6675.h>
LiquidCrystal_I2C lcd(0x27,16,2);
//other large lcd is address 3F
const int sensorMin = 0; // sensor minimum
const int sensorMax = 1023; // sensor maximum
int potPin = A3;
int thermoDO = 8;
int thermoCS = 7;
int thermoCLK = 6;
int heater = 9;
int LiquidCrystal_I2C;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
lcd.begin(16,2);
pinMode(heater, OUTPUT);
pinMode( potPin,INPUT);
Serial.println("MAX6675 test");
// wait for MAX chip to stabilize
//temp read start
int settemp = analogRead(potPin);
delay (100);
settemp = map(settemp, 0, 1023, 40, 95);
//Serial.println(settemp);
Serial.print("SET ");
Serial.print(settemp);
lcd.setCursor (0,0); // set the cursor to 3,0
lcd.print ("SET ");
if (settemp > 100) // if the temperature exceeds your chosen settemp
lcd.clear();
//lcd.setCursor (5,0);
//lcd.print (''); //dont print any spaces
lcd.print ("SET ");
else if (settemp < 10)
//lcd.setCursor (7,0);
lcd.print (' '); // print 2 space
//lcd.setCursor (6,0);
lcd.print (' '); // print 1 spaces
//if over hundred go to 5
lcd.print (settemp);
delay (100); // wait for the lcd to refresh every 250 milliseconds
int currenttemperature = thermocouple.readCelsius();
lcd.setCursor (0,1); // set the cursor to 3,0
lcd.print ("TEMP ");
if (currenttemperature > 100) // if the temperature exceeds your chosen settemp
lcd.clear();
else if (currenttemperature < 10)
lcd.print (currenttemperature);
delay (100);
Serial.print(" C = ");
Serial.println(currenttemperature);
if(currenttemperature < settemp)
digitalWrite(heater, HIGH);
digitalWrite(heater, LOW);
Serial.println("heater off");
if(currenttemperature == 0)
Serial.println("faulty thermocouple");
lcd.clear();
im new at this so the code may also be lacking. did run on pro mini before and worked fine.
