i2c lcd Wemos D1 mini forces hard reset while using interrupt
The moment i want to do a action to the display the Wemos does a hard reset.
Doesn't matter if the interrupt is triggered or not.
I'm at it for over 2 days and still i'm nowhere near to get it working.
I'm not even a step closer than when i started.
Please please help
#define InterruptPIN D6
My Libs:
#include <Arduino.h>
#define FASTLED_INTERNAL
#include <Wire.h>
#include <hd44780.h> // main hd44780 header
#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header
#include <FastLED.h>
My Interrupt:
void ISRC() {
buttonState = digitalRead(InterruptPIN);
last = millis() - lastDebounceTime;
if ( last > debounceDelay) {
if ( buttonState == LOW ){
Serial.println("Interrupt Detected");
if(_state == 0)
msg = "0-NanoHex Ring";
stepRing = true;
stepLED = false;
_state = 1;
p = NanoHex(NUM_RINGS, NUM_LEDS_RING, stepRing, stepLED);
else if(_state == 1)
msg = "1-NanoHex LED";
stepRing = true;
stepLED = true;
_state = 2;
else if(_state == 2)
msg = "2-NanoHex";
stepRing = false;
stepLED = false;
_state = 3;
} else if(_state == 3)
msg = "3-Test 0 pos";
_state = 0;
// TODO: Add Fire
Serial.print("stepRing: ");
Serial.println(stepRing);
Serial.print("stepLED: ");
Serial.println(stepLED);
Serial.print("State2: ");
Serial.println(buttonState);
lastDebounceTime = millis(); //set the current time
My Void:
if(ScreenBacklightOff.ready() && isOn){
isOn = false;
detachInterrupt(digitalPinToInterrupt(InterruptPIN));
delay(40);
//lcd.off();
attachInterrupt(digitalPinToInterrupt(InterruptPIN), ISRC, FALLING);
if(OldMsg != msg){
delay(40);
if(isOn == false){
//lcd.on();
isOn = true;
lcd.clear();
lcd.print(msg);
OldMsg = msg;
delay(40);
if(oneSec.ready()){
Serial.print("Do NaNoHex stuff => ");
Serial.println(x);
if(_state == 0 || _state == 1 || _state == 2){
Serial.println(msg);
p.Draw();
} else if(_state == 3){
t.Draw();
} else if(_state == 4){
FastLED.clear();
f.DrawFire();
FastLED.show(g_Brightness);
Serial.print("State => ");
Serial.println(_state);
x++;
Please show the full sketch between code-tags. You get the code-tags with the </> button.
Why are you turning on and off the interrupts so many times ?
Can you tell which libraries you use (with links to them).
Do you have a schematic ? A photo of a drawing is okay.
Can you make a photo of your project ?
How is the ledstrip powered ? How many leds are there ?
A voltage drop is the most likely reason.
Perhaps your USB cable it too cheap and the board resets when the display background is turned on. Perhaps the ledstrip does not get enough power. Can you measure the 5V pin and the 3.3V pin ?
