Can you show us your schematic? Can you show us which LCD you are using and how you have it hooked up to this chip? Have you tried sending a 1 instead of a 0 (I know the datasheet says inverse logic; but maybe the backlight on the LCD also relies on inverse logic, so you need the equivalent of a double negative to get it to turn on? Its all a guess to me, though, without having a schematic and info on the LCD).
How did you come by this device - did you purchase it, or did you find it on the side of the road (it happens)? I know I have found plenty of chips in junk bins that were in those bins for a reason…
Bought it from eBay, but the guy sells plenty of I2C devices, and did send it neatly in combination with a CD on which was the datasheet. So I think its a decent product. The shop made the datasheet themselves. I mailed them but they havent reacted yet.
What I think is that something is wrong with my code. I hooked op a same LCD as in the datasheet, a HD47780. Also used the wiring scheme of the datasheet.
Did I used the code properly, because thats the only thing that I think is wrong. When I send another command than blacklight it doesn't work either....
Got it figured out You had to divide the start adress by two, for a 7 bit conversion, or what so ever? Also the arduino automatically sended the end bit, because I didn’t had to send that one…
Anyway, the code:
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
byte x = 0;
Wire.beginTransmission(0x21); // join I2C, talk to BV4206 by Addr 31 (7bit) = 62 BV addr (default).
Wire.send(0x03); //blacklight adress
Wire.send(0x00); //on
Wire.endTransmission();
