Hi guys, this is a call for help to build an I2C library for the SW6115 chip thats found on most of the 18650 battery modules (Like those from DIYmore).
The library should allow the user to read various info about the batteries via I2C (stuff like charging status, temp, capacity, and so on)
I have been searching around and it looks like the problem until now has been the lack of a datasheet for the chip in english.
Great news is I made it my personal mission to find the neccesary information.
After weeks of searching the all the dark corners of the internet, signing up to a bunch of chinese forums, and selling my soul to the devil, I have found an english copy of the datasheet, and the I2C protocol !!!!!!!!!
I am able to offer the technical information I have aquired, and carry out testing of the library.
I hope someone with adequate knowlage of I2C and building libraries could help with the writing of the library. Its probably super easy for someone who knows what they are doing. And Im sure it would be very usefull to alot of other people
And together we can produce something cool for the community!!
It seems to be easy enough to write a library for this chip, but will it be useful ? Battery modules using this chip probably doesn't give easy access to the I2C pins and use LEDs to indicate charge status, disallowing the use of the I2C interface (as said in the datasheet).
I have tested it out but Im not getting any usable data.
Both r14 and r15 are showing 255
Here is my sketch:
#include <Wire.h>
Wire.begin();
Wire.beginTransmission( 0x3C );
Wire.write( 0x14 );
Wire.write( 0x15 );
Wire.endTransmission();
Wire.requestFrom( 0x3c, 2 );
uint8_t r14 = Wire.read();
uint8_t r15 = Wire.read();
float vBat = (((r15 << 8) | r14) & 0xFFF) * 1.2;
Serial.println(vBat,5);
Serial.println(r14);
Serial.println(r15);
I have pin 20 on the chip grounded, as per diagram in the datasheet.
I have tested with and without pullups, no difference.
With pullups (12k) I measured with a multimeter and I am reading ~3.3v (unfortunately no oscilloscope at hand). The signal wires are not getting pulled down by the chip or MCU??
Am I maybe missing some initialization steps in my code?
Many I2C devices allow to read multiple registers at once because they have an automatic address increment feature, maybe this chip doesn't have this feature (nothing about it in the datasheet) so you will need to read each registers separately
To be honest I don't know much about I2C, maybe there is another way
I have started building the library but I cant get it working..
I cant figure out how to get it working though
I get the following error message:
C:\Users\MickW\Documents\Arduino\libraries\arduino_sw6115-main\src\SW6115.cpp: In member function 'float SW6115::readVoltage()':
C:\Users\MickW\Documents\Arduino\libraries\arduino_sw6115-main\src\SW6115.cpp:13:14: error: 'ADC_VDATA_1' was not declared in this scope
_bus->write(ADC_VDATA_1);
C:\Users\MickW\Documents\Arduino\libraries\arduino_sw6115-main\src\SW6115.cpp:18:14: error: 'ADC_VDATA_2' was not declared in this scope
_bus->write(ADC_VDATA_2);
Using library arduino_sw6115-main at version 0.0.1 in folder: C:\Users\MickW\Documents\Arduino\libraries\arduino_sw6115-main
Using library Wire at version 1.0.1 in folder: C:\Users\MickW\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire
exit status 1
Error compiling for board ESP32 Dev Module.
Unlike with the MCP23017, your chip address is always 0x3C and cannot be changed, so you don't need the address parameter in the constructor, just replace uint8_t _deviceAddr; by const uint8_t _deviceAddr = 0x3C;
Because the address can't be changed, you can only have one SW6115 on the I2C bus (or you need additional hardware), so you could create a SW6115 object directly in your class (for example add SW6115 Battery; at the end of .h, after the class definition), so that you don't have to do it everytime in the sketch (like Wire, Serial, etc).
You could simplify all readXX functions by making a generic readRegister function (just like in the MCP23017 library I linked)
