Hi everyone,
I have a question and need suggestion about master and slave setup.
In a setup with NodeMCU as master and 2 Arduino UNO's as slaves, slaves should receive data from i2c sensors and send that to master. When I check the individual serial monitors of each slave, I can see the sensors data. But when I check the master's serial monitor, I can only see the slave 1 data but not slave 2.
Could you please find out what's wrong with my code? and give me a solution for my problem. Would really appreciate for inputs on this.
Slave 1 - Arduino UNO
#include <Wire.h>
#include <avr/wdt.h>
////////////////////////scd
#include "SparkFun_SCD30_Arduino_Library.h" //Click here to get the library: http://librarymanager/All#SparkFun_SCD30
SCD30 airSensor;
/////////////////////////////////////////bmp
#include <Adafruit_BMP280.h>
Adafruit_BMP280 bmp; // use I2C interface
Adafruit_Sensor *bmp_temp = bmp.getTemperatureSensor();
Adafruit_Sensor *bmp_pressure = bmp.getPressureSensor();
float array3[1];
//--INA219 current sensor--------------------------
#include <Adafruit_INA219.h>
Adafruit_INA219 ina219;
float shuntvoltage = 0;
float busvoltage = 0;
float current_mA = 0;
float power_mW = 0;
float loadvoltage = 0;
float array1[3];
float co2 = 0;
float co2hum = 0;
float co2temp = 0;
float pressure = 0;
char co2s[7];
char co2temps[5];
char co2hums[5];
char pressures[5];
//MQ8 variables
float MQ8sensorValue;
float array2[3];
#define MQ_PIN (A0) //define which analog input channel you are going to use
#define RL_VALUE (10) //define the load resistance on the board, in kilo ohms
#define RO_CLEAN_AIR_FACTOR (70) //RO_CLEAR_AIR_FACTOR=(Sensor resistance in clean air)/RO,
//which is derived from the chart in datasheet
/***********************Software Related Macros************************************/
#define CALIBARAION_SAMPLE_TIMES (50) //define how many samples you are going to take in the calibration phase
#define CALIBRATION_SAMPLE_INTERVAL (500) //define the time interal(in milisecond) between each samples in the
//cablibration phase
#define READ_SAMPLE_INTERVAL (50) //define how many samples you are going to take in normal operation
#define READ_SAMPLE_TIMES (5) //define the time interal(in milisecond) between each samples in
//normal operation
/**********************Application Related Macros**********************************/
#define GAS_H2 (0)
/*****************************Globals***********************************************/
float H2Curve[3] = {2.3, 0.93, -1.44}; //two points are taken from the curve in datasheet.
//with these two points, a line is formed which is "approximately equivalent"
//to the original curve.
//data format:{ x, y, slope}; point1: (lg200, lg8.5), point2: (lg10000, lg0.03)
float Ro = 15; //Ro is initialized to 10 kilo ohms
#define MUX_Address 0x70 // TCA9548A Encoders address
// Initialize I2C buses using TCA9548A I2C Multiplexer
void tcaselect(uint8_t i2c_bus) {
if (i2c_bus > 7) return;
Wire.beginTransmission(MUX_Address);
Wire.write(1 << i2c_bus);
Wire.endTransmission(true);
// But please don't sue me if it doesn't work.
bool Would_I2C_Hang(int SDAPin, int SCLPin) {
bool wouldHang = false;
pinMode(SDAPin, INPUT);
pinMode(SCLPin, INPUT);
if ( digitalRead(SDAPin) != 1 ) {
Serial.println("SDA pin is low");
wouldHang = true;
if ( digitalRead(SCLPin) != 1 ) {
Serial.println("SCL pin is low");
wouldHang = true;
return wouldHang;
Serial.begin(230400);
for (int i = 5; i > 0; i--) {
Serial.print(i);
delay(1000); // I sometimes need a few seconds to restart the serial console.
wdt_enable(WDTO_4S);
if ( Would_I2C_Hang(20, 21) ) { // Adafruit Feather M0 sda and sdl arduino pins.
Serial.println("The I2C bus will hang if we try to use it. Disabling it.");
Serial.println("Mark the I2C devices as ready to be tested.");
Wire.begin(0x02);
SensorInit(); // Initialize the displays
Wire.onRequest(Request);
void SensorInit() {
tcaselect(0); // channel 0 --> SCD30
Serial.println("Channel 1 of Mux");
Serial.println("SCD30 Example");
Wire.begin();
if (airSensor.begin() == false)
Serial.println("Air sensor not detected. Please check wiring. Freezing...");
while (1)
tcaselect(3); // channel 2 INA219 --> BMP280
ina219.begin();
ina219.setCalibration_16V_400mA(); // set measurement range to 16V, 400mA
tcaselect(7); // channel 7 --> BMP280
////////pressure///////////////
Serial.println(F("BMP280 Sensor event test"));
if (!bmp.begin(0x76)) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring!"));
delay(10);
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL, /* Operating Mode. */
Adafruit_BMP280::SAMPLING_X2, /* Temp. oversampling */
Adafruit_BMP280::SAMPLING_X16, /* Pressure oversampling */
Adafruit_BMP280::FILTER_X16, /* Filtering. */
Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
bmp_temp->printSensorDetails();
MQ8(array2);
if (airSensor.dataAvailable())
Serial.print("co2(ppm):");
Serial.print(airSensor.getCO2());
co2 = airSensor.getCO2();
Serial.print(" temp(C):");
Serial.print(airSensor.getTemperature(), 1);
co2temp = airSensor.getTemperature();
Serial.print(" humidity(%):");
Serial.print(airSensor.getHumidity(), 1);
co2hum = airSensor.getHumidity();
Serial.print(" Pre-stream data");
Serial.print(co2);
Serial.print(co2temp);
Serial.print(co2hum);
tcaselect(3);
shuntvoltage = ina219.getShuntVoltage_mV();
busvoltage = ina219.getBusVoltage_V();
current_mA = ina219.getCurrent_mA();
power_mW = ina219.getPower_mW();
loadvoltage = busvoltage + (shuntvoltage / 1000);
Serial.print("Load Voltage: "); Serial.print(loadvoltage); Serial.println(" V");
Serial.print("Current: "); Serial.print(current_mA); Serial.println(" mA");
Serial.println("");
array1[0] = busvoltage;
array1[1] = shuntvoltage;
array1[2] = loadvoltage;
array1[3] = current_mA;
sensors_event_t temp_event, pressure_event;
bmp_temp->getEvent(&temp_event);
bmp_pressure->getEvent(&pressure_event);
Serial.print(F("Temperature = "));
Serial.print(temp_event.temperature);
Serial.println(" *C");
Serial.print(F("Pressure = "));
Serial.print(pressure_event.pressure);
Serial.println(" hPa");
array3[1] = temp_event.temperature;
wdt_reset();
//MQ8 readings function
void * MQ8(float array2[3])
MQ8sensorValue = analogRead(A0);
Serial.print("H2 Concentration:");
float ppm = MQGetGasPercentage(MQRead(MQ_PIN) / Ro, GAS_H2);
Serial.print(ppm );
Serial.print( "ppm" );
Serial.print("\n");
array2[0] = MQ8sensorValue;
array2[1] = ppm;
//delay(15000);
//****************** MQResistanceCalculation ****************************************
float MQResistanceCalculation(int raw_adc) {
return ( ((float)RL_VALUE * (1023 - raw_adc) / raw_adc));
float MQCalibration(int mq_pin) {
int i;
float val = 0;
for (i = 0; i < CALIBARAION_SAMPLE_TIMES; i++) { //take multiple samples
val += MQResistanceCalculation(analogRead(mq_pin));
delay(CALIBRATION_SAMPLE_INTERVAL);
val = val / CALIBARAION_SAMPLE_TIMES; //calculate the average value
val = val / RO_CLEAN_AIR_FACTOR; //divided by RO_CLEAN_AIR_FACTOR yields the Ro
//according to the chart in the datasheet
return val;
float MQRead(int mq_pin) {
int i;
float rs = 0;
for (i = 0; i < READ_SAMPLE_TIMES; i++) {
rs += MQResistanceCalculation(analogRead(mq_pin));
delay(READ_SAMPLE_INTERVAL);
rs = rs / READ_SAMPLE_TIMES;
return rs;
int MQGetGasPercentage(float rs_ro_ratio, int gas_id) {
if ( gas_id == GAS_H2) {
return MQGetPercentage(rs_ro_ratio, H2Curve);
return 0;
int MQGetPercentage(float rs_ro_ratio, float *pcurve) {
return (pow(10, ( ((log(rs_ro_ratio) - pcurve[1]) / pcurve[2]) + pcurve[0])));
void Request()
//Converting float value to char
//The format (float, bytes, numbers of numbers after the decimal, char variable)
delay(2000);
dtostrf(co2, 7, 1, co2s);
Wire.write(co2s); // appx 8 bytes
Wire.write(",");
dtostrf(co2temp, 4, 1, co2temps);
Wire.write(co2temps); // appx 8 bytes
Wire.write(",");
dtostrf(co2hum, 4, 1, co2hums);
Wire.write(co2hums); // appx 8
Wire.write(",");
dtostrf(pressure, 6, 4, pressures);
Wire.write(pressures); // appx 8
Wire.write("\n");
Slave 2 - Arduino UNO
#include <Wire.h>
SCD30 airSensor;
float array3[1];
float power_mW = 0;
float loadvoltage=0;
float array1[3];
float co2 = 0;
float co2hum = 0;
float co2temp = 0;
float pressure = 0;
char co2s[7];
char co2temps[5];
char co2hums[5];
char pressures[5];
//MQ8 variables
float array4[3];
//normal operation
#define GAS_H2 (0)
#define MUX_Address 0x71 // TCA9548A Encoders address
wouldHang = true;
wouldHang = true;
return wouldHang;
void setup(){
Serial.print(i);
Wire.begin(0x04);
void SensorInit(){
Wire.begin();
while (1)
ina219.begin();
delay(10);
void loop(){
while (0 <Wire.available()) {
char d = Wire.read(); /* receive byte as a character */
Serial.print(d); /* print the character */
MQ8(array4);
co2=airSensor.getCO2();
co2temp=airSensor.getTemperature();
co2hum=airSensor.getHumidity();
Serial.print(co2);
tcaselect(3);
Serial.println("");
array1[2] =loadvoltage;
//float pressure_pascal=pressure_event.pressure/1000 - 0.90883;
wdt_reset();
void * MQ8(float array4[3])
float ppm=MQGetGasPercentage(MQRead(MQ_PIN) / Ro, GAS_H2);
Serial.print(ppm );
Serial.print("\n");
array4[0] = MQ8sensorValue;
array4[1] = ppm;
//delay(15000);
int i;
float val = 0;
return val;
int i;
float rs = 0;
return rs;
return 0;
void Request()
delay(2000);
Wire.write(",");
Wire.write(",");
Wire.write(",");
Wire.write("\n");
Master - NodeMCU
#include "FirebaseESP8266.h" // Install Firebase ESP8266 library
#include <esp8266wifi.h>//<ESP8266WiFi.h>
#define FIREBASE_HOST "********************************"
#define FIREBASE_AUTH "***********************************"
#define WIFI_SSID "****************"
#define WIFI_PASSWORD "************************"
FirebaseData firebaseData;
#include <Wire.h>
float co2ppm = 0;
float co2temp = 0;
float co2hum = 0;
float pressure = 0;
//////////////////// slave 2
float co2ppm2 = 0;
float co2temp2 = 0;
float co2hum2 = 0;
float pressure2 = 0;
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(115200); // start serial for output
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to Wi-Fi");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
delay(300);
Serial.print("Connected with IP: ");
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
Firebase.reconnectWiFi(true);
delay(5000);
Wire.requestFrom(0x02, 23);
delay(2000);
String datastream1, co2ppms, co2temps, co2hums, pressures;
do // slave may send less than requested
char c = Wire.read(); // receive a byte as character
datastream1 = datastream1 + c; //Keep saving whatever is comming
co2ppms = datastream1.substring(0, 7); //slpit String from 0 to 8
co2temps = datastream1.substring(8, 12); // Split from 9 to the End of String
co2hums = datastream1.substring(13, 17);
pressures = datastream1.substring(18, 23);
} while (Wire.available());
Serial.print("Recieving float as String...");
Serial.print("Datastream...");
Serial.print(datastream1);
Serial.print("CO2 PPM: ");
Serial.print(co2ppms);
Serial.print("CO2 TEMP: ");
Serial.print(co2temps);
Serial.print("CO2 HUM: ");
Serial.print(co2hums);
Serial.print("Pressure: ");
Serial.print(pressures);
Serial.print("Converting string to float...");
co2ppm = co2ppms.toFloat();
Serial.print(co2ppm);
co2temp = co2temps.toFloat();
co2hum = co2hums.toFloat();
pressure = pressures.toFloat();
Serial.print("PRESSURE: ");
Serial.print(pressure);
//-firebase-----------------------------------------------
////////////////////////////////////// Firebase data//////////////////////
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH); // connect to firebase
///////////////Variable one - CO2 PPM//////////////
if (Firebase.setFloat(firebaseData, "/Reactors/Slave1/CO2 PPM", co2ppm)) { // On successful Write operation, function returns 1
Serial.println("Value Uploaded Successfully");
Serial.print("CO2 PPM= ");
Serial.println(co2ppm);
Serial.println("\n");
//val++;
else {
Serial.println(firebaseData.errorReason());
///////////////Variable 2 - CO2 TEMP//////////////
if (Firebase.setFloat(firebaseData, "/Reactors/Slave1/CO2 Temp", co2temp)) { // On successful Write operation, function returns 1
Serial.print("CO2 TEMP= ");
Serial.println(co2temp);
//val++;
else {
///////////////Variable 3 - CO2 HUM//////////////
if (Firebase.setFloat(firebaseData, "/Reactors/Slave1/ CO2HUM", co2hum)) { // On successful Write operation, function returns 1
Serial.print("CO2 HUM= ");
Serial.println(co2hum);
//val++;
else {
///////////////Variable 4 - Pressure//////////////
if (Firebase.setFloat(firebaseData, "/Reactors/Slave1/ Pressure", pressure)) { // On successful Write operation, function returns 1
Serial.print("Pressure= ");
Serial.println(pressure);
//val++;
else {
delay (1000);
// ///2nd slave
delay(5000);
Serial.print("Recieving from slave 2...");
Wire.requestFrom(0x04, 23);
String datastream2, co2ppms2, co2temps2, co2hums2, pressures2;
char d = Wire.read(); // receive a byte as character
datastream2 = datastream2 + d; //Keep saving whatever is comming
co2ppms2 = datastream2.substring(0, 7); //slpit String from 0 to 8
co2temps2 = datastream2.substring(8, 12); // Split from 9 to the End of String
co2hums2 = datastream2.substring(13, 17);
pressures2 = datastream2.substring(18, 23);
Serial.print(datastream2);
Serial.print(co2ppms2);
Serial.print(co2temps2);
Serial.print(co2hums2);
Serial.print(pressures2);
co2ppm2 = co2ppms2.toFloat();
Serial.print(co2ppm2);
co2temp2 = co2temps2.toFloat();
Serial.print(co2temp2);
co2hum2 = co2hums2.toFloat();
Serial.print(co2hum2);
pressure2 = pressures2.toFloat();
Serial.print(pressure2);
// Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH); // connect to firebase
// Firebase.reconnectWiFi(true);
if (Firebase.setFloat(firebaseData, "/Reactors/Slave2/CO2 PPM", co2ppm2)) { // On successful Write operation, function returns 1
Serial.println(co2ppm2);
//val++;
else {
if (Firebase.setFloat(firebaseData, "/Reactors/Slave2/CO2 Temp", co2temp2)) { // On successful Write operation, function returns 1
Serial.println(co2temp2);
//val++;
else {
if (Firebase.setFloat(firebaseData, "/Reactors/Slave2/ CO2HUM", co2hum2)) { // On successful Write operation, function returns 1
Serial.println(co2hum2);
//val++;
else {
if (Firebase.setFloat(firebaseData, "/Reactors/Slave2/ Pressure", pressure2)) { // On successful Write operation, function returns 1
Serial.println(pressure2);
//val++;
else {
Serial.println("");
