I2C Max7310 ADS1112
I have developed a project initially that works with the Mega ... do to SRAM constraints I have swapped out the mega for the Due.
But now I cannot get the I2C to work .... unfortunately my low level knowledge is not good.
Is there a difference with the I2C hardware of the mega v due that would create this difference? I'm looking for help how to understand and resolve this?
I do have a DFRobot SD2403 RTC on the I2C.and this continues to work?
Thanks
SCL / SDA did have pullups build in but not SCL1 / SDA1.
On SCL1/ SDA1 you need Pullups about 2k2 Ohm on both and replace everywhere wire by wire1 in :
Wire.beginTransmission();
Wire.write();
Wire.endTransmission();
Wire.requestFrom();
Therefore at the beginning of your sketch, when using SCL1 / SDA1, you will have :
#include <Wire.h>
#define Wire Wire1
... and it should work
