I just got two of these 16 relay boards which use the MCP23016 controller and noticed that nobody had anything that really worked so today I wrote two simple programs that really work. This is a 12V board. There is no place to connect +5V from the I2C connector, so don't do it, you only need GND, SDA and SCL.
Test Program for the 12CZXRELAY16 Board from inexglobal.com
16 Relay Scanner Night Rider Style (for the fun of it)
made by EdArmstrong@testelectronics.com
December 27th 2010
#include <Wire.h>
//#define MCP23016_I2C_WRITE 0x40 //do not use, the chip is 7 bit so the library adds a LSB bit so 0x40 becomes 0x20
//#define MCP23016_I2C_READ 0x41 //do not use
#define MCP23016_I2C 0x20 //the library adds last bit so it makes it a 0x40
// COMMAND BYTE TO REGISTER RELATIONSHIP
#define GP0 0x00 // PORT0 first 8 relays
#define GP1 0x01 // PORT1 second 8 relays
#define OLAT0 0x02 // LATCH0 command to write on latch 0 first 8 relays
#define OLAT1 0x03 // LATCH1 command to write on latch 1 second 8 relays
#define IPOL0 0x04 // INPUT POLARITY PORT REGISTER 0
#define IPOL1 0x05 // INPUT POLARITY PORT REGISTER 1
#define IODIR0 0x06 // I/O DIRECTION REGISTER 0
#define IODIR1 0x07 // I/O DIRECTION REGISTER 1
#define INTCAP0 0x08 // INTERRUPT CAPTURE REGISTER 0
#define INTCAP1 0x09 // INTERRUPT CAPTURE REGISTER 1
#define IOCON0 0x0A // I/O EXPANDER CONTROL REGISTER 0
#define IOCON1 0x0B // I/O EXPANDER CONTROL REGISTER 1
#define PAUSE 100
Wire.begin(); // join i2c bus (address optional for master)
write_io (IODIR0, 0x00); //sets direction to output
write_io (IODIR1, 0x00);
write_io (GP0, B00000000); //clears all relays
write_io (GP1, B00000000);
delay (PAUSE);
write_io (GP0, B00000001);
delay (PAUSE);
write_io (GP0, B00000010);
delay (PAUSE);
write_io (GP0, B00000100);
delay (PAUSE);
write_io (GP0, B00001000);
delay (PAUSE);
write_io (GP0, B00010000);
delay (PAUSE);
write_io (GP0, B00100000);
delay (PAUSE);
write_io (GP0, B01000000);
delay (PAUSE);
write_io (GP0, B10000000);
delay (PAUSE);
write_io (GP1, B00000001);
delay (PAUSE);
write_io (GP1, B00000010);
delay (PAUSE);
write_io (GP1, B00000100);
delay (PAUSE);
write_io (GP1, B00001000);
delay (PAUSE);
write_io (GP1, B00010000);
delay (PAUSE);
write_io (GP1, B00100000);
delay (PAUSE);
write_io (GP1, B01000000);
delay (PAUSE);
write_io (GP1, B10000000);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
delay (PAUSE);
void write_io(int command, int value)
Wire.beginTransmission(MCP23016_I2C);
Wire.send(command),Wire.send(value); // reset register pointer then set GP0 to push_this // use (0,??)
Wire.endTransmission();
