I2C Multiplexer- Print Address and Ports
Hi everyone! I have set up a Uno board with a TCA9548A multiplexer and using 2 magnetometers (MAG3110) which have the same address (0x0E!
I'm trying to get an Arduino code to print the address of the Multiplexer (0x70) and then use that address to detect the ports.
This is a code I have doing that (Found some examples on detecting I2C address and on detecting ports on multiplexer). Again this code works but I'm defining an Address for it to search.
#include "Wire.h"
extern "C" {
#include "utility/twi.h"  // from Wire library, so we can do bus scanning
#define TCAADDR 0x70
int counter = 0;
void Scanner() {
  byte error, address;
  int nDevices;
  Serial.println("Scanning for I2C Address...");
  nDevices = 0;
  for (address = 1; address < 127; address++ ) // Search for 0x00 to 0x127
    // If there is a device, return the address.
    // If no device, go through errors and end.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address, HEX);
      nDevices++;
    else if (error == 4)
      Serial.print("Unknown error at address 0x");
      if (address < 16)
        Serial.print("0");
  if (nDevices == 0)
    Serial.println("No I2C devices found");
void tcaselect(uint8_t i) {
  if (i > 7) return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << i);
void Portfinder() {
  Scanner(); // Call Scanner to Find Addres
  Serial.println("-------------------------");
  Serial.println("I2C Port Detection Started.");
  for (uint8_t t = 0; t < 8; t++) {
    tcaselect(t);
    Serial.print("TCA Port #"); Serial.println(t);
    for (uint8_t addr = 0; addr <= 127; addr++) {
      if (addr == TCAADDR) continue;
      uint8_t data;
      if (! twi_writeTo(addr, &data, 0, 1, 1)) {
        Serial.print("Found I2C 0x");  Serial.println(addr, HEX);
  Serial.println("Detection of I2C Ports Finished.");
// standard Arduino setup()
  while (!Serial);
  delay(100);
  Wire.begin();
  Portfinder(); //Call Port finder function
  counter += 1;
  delay(10000); //Wait 10 seconds to rescan
Now I would essentially need the Scanner() function to return the address so I can feed that into the Portfinder() function.. I have tried this -
#include "Wire.h"
extern "C" {
//#define TCAADDR 0x70
int counter = 0;
float ADD;
void tcaselect(uint8_t i, int ADD) {
  if (i > 7) return;
  Wire.beginTransmission(ADD);
  Wire.write(1 << i);
void Portfinder() {
  ADD = Scanner();
  Serial.println(ADD);
  Serial.println("-------");
  Serial.println("I2C Port Scanner Started.");
    tcaselect(t, ADD);
      if (addr == ADD) continue;
      uint8_t data;
  while (!Serial);
  delay(100);
  Wire.begin();
  Portfinder();
  counter += 1;
  delay(3000);
int Scanner() {
  int nDevices;
  nDevices = 0;
    if (error == 0)
      if (address < 16)
        Serial.print("0");
      nDevices++;
      if (address < 16)
        Serial.print("0");
    return (address, HEX);
  if (nDevices == 0)
    Serial.println("done");
The problem with making this function an INT (since I cant make it a HEX) or maybe that's not the problem at all... the address it returns is 16... Now I know I need to get back 70 in hex or 112 in decimal.
So to recap... I'm trying to get the Scanner() function to RETURN the address, so I can feed that address to the Portfinder() function (Currently #define TCAADDR 0x70 is giving it the right address - I want to have it find this address on it's own). I'm a bit rusty on my Arduino/C skills, any feedback would be nice!
Thank you! :slight_smile:
Try this:
#include "Wire.h"
//extern "C" {
//#include "utility/twi.h"  // from Wire library, so we can do bus scanning
int counter = 0;
  if (i > 7) return;
  Wire.write(1 << i);
void Portfinder(int addr) {
  Serial.println(addr);
    tcaselect(t, addr);
    ExtScanner(addr);
  while (!Serial);
  delay(100);
  Wire.begin();
  int address = Scanner();
  if ( address > 0 ) {
    Portfinder(address);
  counter += 1;
  delay(3000);
int Scanner() {
  // search for TCA9548A address 0x70 to 0x77
  for (address = 0x70; address < 0x77; address++ ) // Search for 0x00 to 0x127
    if (error == 0)
      if (address < 16)
        Serial.print("0");
      return address;
      if (address < 16)
        Serial.print("0");
      return 0;
  return 0;
void ExtScanner(int addr) {
  // search for decides beyond TCA9548A
    if ( address == addr ) continue;  // skip the TCA9548A
    if (error == 0)
      if (address < 16)
        Serial.print("0");
      if (address < 16)
        Serial.print("0");
It's almost there but still doesn't work. It's definitely closer but no luck. I will work on it more. Any other advice would be helpful as well! Thanks!
"Doesn't work" is the worst possible description. What doesn't work? How is it working vs. what you expect? What is being displayed on the serial monitor?
