I'm fairly novice with programming and I am hoping that someone can help me with a challenge that I'm facing with my project. (I also hope that I've posted this in the correct group)
I am trying to connect three pressure sensors to an I2C Multiplexer using a Seeeduino.
I have been able to successfully read data individually with another setup that includes the sensors, but I cannot seem to get the same results using this multiplexer.
I have adapted some code from the TCA9548A documentation as well as code for the pressure sensors.
My first guess is that I have a memory issue, because all of the values that I receive are the same. What is also curious is that when I unplug the power cable, the values continue to roll through the serial monitor as if the pressure sensors are not even connected. The first section of code shows that the sensors are in-fact connected, but the values that I am printing must not be from the sensors...
I do not really understand what is happening with the memory here... can anyone help?
Here is my code:
#include <Wire.h>
extern "C"
#include "utility/twi.h"
#define TCAADDR 0x70
unsigned long Coff[6], Ti = 0, offi = 0, sensi = 0;
unsigned int data[3];
void tcaselect(uint8_t i)
if(i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
Wire.begin();
//pinMode(0, OUTPUT);
Serial.println("\nTCAScanner ready!");
for(uint8_t t=1; t<=3; t++)
tcaselect(t);
Serial.print("TCA Port #");
Serial.println(t);
for(uint8_t addr = 0; addr <= 127; addr++)
if(addr == TCAADDR) continue;
uint8_t data;
if(! twi_writeTo(addr, &data, 0, 1, 1))
Serial.print("Found I2C 0x");
Serial.println(addr, HEX);
for(int i = 0; i < 6; i++)
Wire.write(0xA2 + (2*i));
Wire.requestFrom(TCAADDR, 2);
if(Wire.available() == 2)
data[0] = Wire.read();
data[1] = Wire.read();
Coff[i] = ((data[0]*256) + data[1]);
delay(10);
Serial.println("\nDone!");
for(uint8_t i = 1; i <= 3; i++)
//tcaselect(i);
Wire.write(0x1E);
delay(10);
//tcaselect(i);
Wire.write(0x40);
delay(10);
//tcaselect(i);
Wire.write(0x00);
delay(10);
Wire.requestFrom(TCAADDR, 3);
if(Wire.available() == 3)
data[2] = Wire.read();
unsigned long ptemp = ((data[0]*65536.0) + (data[1]*256.0) + data[2]);
//tcaselect(i);
Wire.write(0x50);
delay(10);
//tcaselect(i);
Wire.write(0x00);
unsigned long temp = ((data[0] * 65536.0) + (data[1] * 256.0) + data[2]);
unsigned long dT = temp - ((Coff[4] * 256));
temp = 2000 + (dT * (Coff[5] / pow(2, 23)));
unsigned long long off = Coff[1] * 262144 + (Coff[3] * dT) / 32;
unsigned long long sens = Coff[0] * 131072 + (Coff[2] * dT) / 128;
if(temp < 2000)
Ti = 3 * (dT * dT) / (pow(2,33));
offi = 3 * ((pow((temp - 2000), 2))) / 8;
sensi = 7 * (pow((temp - 2000), 2)) / 8;
if(temp < - 1500)
sensi = sensi + 3 * ((pow((temp + 1500), 2)));
else if(temp >= 2000)
Ti = 0;
offi = 0;
sensi = 0;
temp -= Ti;
off -= offi;
sens -= sensi;
ptemp = (((ptemp * sens) / 2097152) - off);
ptemp /= 32768.0;
float pressure = ptemp / 100.0;
float ctemp = temp / 100.0;
float fTemp = ctemp * 1.8 + 32.0;
if(i == 1)
Serial.print("P");
Serial.print(i);
Serial.print(" = ");
Serial.print(pressure);
Serial.print("\t");
else if(i == 2)
Serial.print("P");
Serial.print(i);
Serial.print("\t");
Serial.print("P");
Serial.print(i);
Serial.print("\n");
delay(10);
//digitalWrite(0, LOW);
Website for the I2C Multiplexer - Arduino Wiring & Test | Adafruit TCA9548A 1-to-8 I2C Multiplexer Breakout | Adafruit Learning System
Website to the Pressure Sensor - http://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Data+SheetMS5803-05BAB3pdfEnglishENG_DS_MS5803-05BA_B3.pdfCAT-BLPS0011
I am using an I2C multiplexer since the addresses of all of the pressure sensors are the same.
Any insights would be greatly appreciated! ![]()
