I have been trying to get my UNO to send a series of bytes out the I2C lines. I have been using the Wire.h library. It seems to send the address byte correctly, but then I can not get it to send out a second byte in a string.
#include <Servo.h>
//#include <EEPROM.h>
#include <Wire.h>
Servo servo;
// Unused pins
pinMode(0, OUTPUT);
digitalWrite(0, HIGH);
pinMode(1, OUTPUT);
digitalWrite(1, HIGH);
pinMode(A0, OUTPUT);
digitalWrite(A0, HIGH);
pinMode(A1, OUTPUT);
digitalWrite(A1, HIGH);
pinMode(A2, OUTPUT);
digitalWrite(A2, HIGH);
//pinMode(A4, OUTPUT);
// digitalWrite(A4, HIGH);
// pinMode(A5, OUTPUT);
// digitalWrite(A5, HIGH);
// Used pins
Wire.begin(); // join i2c bus master
pinMode(A3, INPUT_PULLUP); // Button input with pull-up
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW); // Indicator LED off
pinMode(lspPin, INPUT); // Left speed sensor input
pinMode(rspPin, INPUT); // right speed sensor input
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
digitalWrite(trigPin, LOW);
pinMode(enAPin, OUTPUT);
pinMode(in1Pin, OUTPUT);
pinMode(in2Pin, OUTPUT);
pinMode(in3Pin, OUTPUT);
pinMode(in4Pin, OUTPUT);
pinMode(enBPin, OUTPUT);
servo.attach(servoPin);
byte valq = 0;
Wire.beginTransmission(3); // transmit to device #44 (0x2c)
// device address is specified in datasheet
Wire.write(valq); // sends value byte
Wire.endTransmission(); // stop transmitting
valq++; // increment value
if(valq == 64) // if reached 64th position (max)
valq = 0; // start over from lowest value
delay(100);
In this line either the address byte (3) or the comment (44) is wrong.
How do you know? Why don't you check the result of Wire.endTransmission()? It might give you insights what went wrong. My guess is that you're using a wrong address. Have you tried an I2C scanner sketch?
Koepel:
When the I2C address 0x03 does not exist on the I2C bus, then the rest is not transmitted.
Is it a CAP1188 chip ?
In my earlier use of I2C I don't recall that the target had to ACK the address, in order for the master to continue the transmission. My expectation is that the master continues sending regardless of an ACK from the bus. The peripheral chip in this case is a PCF8574T.
I appreciate your input. Please let me know if you have further ideas.
The comment is wrong.
I am using an oscilloscope to observe the I2C traffic. As I change the address in the Wire.beginTransmission() , I can observe the bits change in the data stream. I am seeing only 8 bits and the termination signal from the master.
