I2C OLED intermittently freezing
I have this tiny OLED for the DataSleeve, but every now and then, the output freezes and the Arduino has to be reset. I found that reducing the refresh rate of the screen helps, but it still happens. I found another thread where someone had the same problem, and replacing their counterfeit Arduino fixed it.
However.
I'm using both a different library AND a different board (still knockoff, my Micro has a corrupted bootloader right now), and it's still happening. Furthermore, the board in my final project isn't genuine either, it's Adafruit's KB2040 with a 3rd party core to get it working in Arduino.
Hardware details:
Knockoff Nano (CH340)
I2C OLED
MPU6050 (I2C)
Rotary encoder
Code: (this code is pointless and serves as R&D)
#include <SPI.h>
#include <MPU6050.h>
#include <Wire.h>
#include <U8g2lib.h>
MPU6050 mpu;
int16_t ax, ay, az, gx, gy, gz;
U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0);
const int buttonPin = 4;
int counter = 0;
int buttonState;
int lastButtonState = LOW;
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50;
  pinMode(buttonPin, INPUT);
  u8g2.begin();
  mpu.initialize();
  if (!mpu.testConnection()) {
    while (1);
  mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
  int reading = digitalRead(buttonPin);
  if (reading != lastButtonState) {
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    if (reading != buttonState) {
      buttonState = reading;
      if (buttonState == LOW && counter >= 0 && counter < 10) {
        counter++;
      else if (buttonState == LOW && counter >= 10) {
        counter = 0;
  lastButtonState = reading;
  switch (counter) {
    case 1:
      printInt(10, 10, ax);
    case 2:
      printInt(10, 10, ay);
    case 3:
      printInt(10, 10, az);
    case 4:
      printInt(10, 10, gx);
    case 5:
      printInt(10, 10, gy);
    case 6:
      printInt(10, 10, gz);
    default:
      printInt(10, 10, 0);
  delay(100)
Uses a secondary function called printInt()
void printInt(int _cursorX, int _cursorY, int _varToPass) {
  u8g2.clearBuffer();
  u8g2.setFont(u8g2_font_t0_11_tf);
  u8g2.setCursor(_cursorX, _cursorY);
  u8g2.print(_varToPass);
  u8g2.sendBuffer();
First thing I would check is if the power (i.e. 5v supply) is good / add a capacitor between them.
I can't tell you how many times I have spent hours trying to find a problem only to later realise it is just a power issue.
Power's coming from USB, and I've never had problems with it before.
Did you find any solution yet ?
@kisscoool18 Do you have problems with the MPU-6050 as well ? It could be a fake sensor. There are so many troubles lately with the MPU-6050 on this forum, you better look for a newer and better sensor.
No, but I have a very similar issue with an OLED display so I'm searching answers.
I've posted more details on my setup here
:slight_smile:
Start a new topic please.
Well my intention wasn't to talk about my issue but to know more about this one, to give me ideas. But yes I will write a new post.
Not sure if it’s any help, but I have a similar unresolved problem - occurs after a couple of days running .
I put a flashing led in my code and I can see that the code is still running fine , but the display is frozen .
So watching this with interest
kisscoool18 created a new topic here: OLED display eventually freeze
If anyone is wondering, I have not found a solution. Actually, I haven't messed with the OLED since I posted. I'll break it back out later and see what happens.
