I have written some code for a humidity control project: based on readings from different sensors, I will control a ventilation system.
The basic setup is: 4xSHT31 connected via TCA9548A I2C Mux.
As some sensors will be pretty far away (further than the advised 2-3m, max 5m away if tests show that that could work) from the TCA9548A, I want to have the wiring as ideal as possible to minimize interference.
I will be using 'alarm cable' (edit: or cat6 utp) which consists of two twisted pairs.
What's the best way to group the cables?
- VCC+GND (pair 1), SCL+SDA (pair 2)
- VCC+SCL (pair 1), GND+SDA (pair 2)
- VCC+SDA (pair 1), GND+SCL (pair 2)
Or is this not relevant at all? If so why ... and what's could be done otherwise to have potential better/more reliable signals.
Kind regards,
Maarten
