I2C over RS422 using MAX485, will this circuit work?
I would like to use I2C to communicate between Arduino controllers using the MAX485 to convert the signal to RS422.
I drew a circuit of how I think it would work. Does this look correct?
https://www.dropbox.com/s/31ir8kst2kcalkx/i2c_over_rs422.JPG
IC1 is a Texas Instruments SN74AHC125N, Buffers & Line Drivers Tri-State Quad Bus. HiZ = High Impedance.
The same circuit would be used for the SDA and SCL.
The cable will have 2 twisted pairs. This should extend the I2C range from 10 feet to 4900 feet.
Eric
As the receiver is always enabled I would say that this circuit drives itself as soon as SDA went low once.
Do you know that I2C extenders exist that allows I2C bus lengths of over 50m? (http://www.nxp.com/documents/data_sheet/P82B715.pdf)
Yes I think that's right, looks like a feedback loop to me.
Any reason not to use the I2C buffer chips? If you need > 50m there are versions that split the SDA and SCL signals into separate lines so you can use RS-485 or other drivers, the PCA9600 for example.
Rob
Thanks. The I2C extender looks like it should work.
