I2C Port expander and keypads for Arduino
Hello,
I used the tutorial http://playground.arduino.cc/Main/I2CPortExpanderAndKeypads to connect a keypad with an I2C expander, and the program works on IDE 023, but gives me errors and cannot compile on IDE 105. I am a beginner in programing and don't know how to detect and change the incompatibilities.
I changed send and receive with read and write and WConstants.h with Arduino.h but then I get errors like this:
In file included from C:...\arduino-1.0.5\hardware\arduino\cores\arduino/HardwareSerial.h:100, from C:...\arduino-1.0.5\hardware\arduino\cores\arduino/Arduino.h:193, from i2ckeypad.cpp:50: C:...\arduino-1.0.5\hardware\arduino\cores\arduino/USBAPI.h:191: error: declaration of C function 'int USB_Recv(uint8_t)' conflicts with C:...\arduino-1.0.5\hardware\arduino\cores\arduino/USBAPI.h:190: error: previous declaration 'int USB_Recv(uint8_t, void*, int)' here In file included from i2ckeypad.cpp:50: C:...\arduino-1.0.5\hardware\arduino\cores\arduino/Arduino.h:196: error: declaration of C function 'uint16_t makeWord(byte, byte)' conflicts with C:...\arduino-1.0.5\hardware\arduino\cores\arduino/Arduino.h:195: error: previous declaration 'uint16_t makeWord(uint16_t)' here C:...\arduino-1.0.5\hardware\arduino\cores\arduino/Arduino.h:206: error: declaration of C function 'long int random(long int)' conflicts with c:/.../arduino-1.0.5/hardware/tools/avr/lib/gcc/../../avr/include/stdlib.h:504: error: previous declaration 'long int random()' here C:...\arduino-1.0.5\hardware\arduino\cores\arduino/Arduino.h:207: error: declaration of C function 'long int random(long int, long int)' conflicts with C:...\arduino-1.0.5\hardware\arduino\cores\arduino/Arduino.h:206: error: previous declaration 'long int random(long int)' here
Can anyone help me with this? Thank you.
You could just use the keypad_I2c library. It's included with the normal keypad library.
http://playground.arduino.cc/code/Keypad
@tack thank you for your answer. I sow that tutorial. It says there "You can find more information inside the docs folder under the Keypad_I2C library folder." But there is no docs folder in the downloaded zip and no information on how to use that library. So I really don't know how to use it.
Anyone knows where I can find those docs?
A quick Google turned up the following, which should help you:-
http://bradsduino.blogspot.co.uk/2013/01/i2c-version-of-using-4x4-universal-16.html
Thank you @tack. Solved the problem.
