I2C prints 0 or 1 instead of string
I'm trying to print message from HM-10 on my LCD (16x2) by the following code
#include <SoftwareSerial.h>
#include <LCD_I2C.h>
SoftwareSerial HM10(2, 3);
LCD_I2C lcd(0x27, 16, 2);
char appData;
String inData = "";
bool needUpdateScreen;
    lcd.begin();
    lcd.backlight();
    HM10.begin(9600);
  HM10.listen();
  while (HM10.available() > 0) {
    appData = HM10.read();
    inData = String(appData);
    Serial.write(inData.c_str());
    Serial.write(appData);
    needUpdateScreen = true;
  if(needUpdateScreen){
    lcd.clear();
    lcd.print(inData);
    //lcd.print("TEST");
    needUpdateScreen = false;
When I print "TEST" it works without any problem. When I print "inData" I see only 1 or 0.
Something wrong with types?
Many thanks!
Solved by using
void serialRead() {
  while (HM10.available()) {
  delay(10);
  if (HM10.available() >0) {
    char c = HM10.read();
    readString += c;}
What do you see on serial monitor? Perhaps 1 and 0 is what is being received?
In serial monitor I see the whole string.
But what is the whole string?
I send "MM1" or "MM0" from my ios app. Now, with the serialRead function I can print the whole message. The strange thing was that serial was printing whole message even without "serialRead" function.
What function is that? I don't see it in your code. If you meant to say Serial.read(), why do you think that would be needed?
