I2C - Problem with onRequest, onReceive
I've problem with IDE 1.5.2 and Arduinu DUE.
My program size: 304,492 bytes Free RAM: cca 70kB [ not 100% ] - used some code to get this number
Problems started after I've added Wire1 as I2C Slave and using : - onRequest - onReceive
The same problem with Wire and Wire1.
Since that program freezes at the same location - not in I2C callback [ I think ] but while drawing to TFT display.
I'm thinking about some Stack issue but can't [ don't know how ] investigate it more.
Wire1.begin(NET_MODULE_WIRE_ADDRESS); Wire1.onRequest(onRequestHandler); Wire1.onReceive(onReceiveHandler);
void onRequestHandler(void) { byte val ; switch (cmd_received) { //je queue prazdna ? case CMD_QUEUE_EMPTY:
Wire1.write(RQX_HEADER); Wire1.write(queue[0].empty);
//receive command from network arduino UNO void onReceiveHandler(int howMany ) {
if(Wire1.available()) { cmd_received = Wire1.read(); }
