i2c problem
Hello,
im working on a project and having problem with my loop. I think the problem starts in readFrom(byte address)
#include <Wire.h>
//define values for slip coding
int escapeChar = 101;
int delimiterChar = 100;
      Wire.begin(); //join i2c bus (address optinal for master)
      Serial.begin(115200); //start serial for output
      //turing on the ADXL345
      writeTo(0x2D, 0);
      writeTo(0x2D, 16);
      writeTo(0x2D, 8);
//Writes val to address register
void writeTo(byte address, byte val)
      Wire.beginTransmission(0x53); //start transmission to device
      Wire.send(address); //send register to address
      Wire.send(val); //send value to write
      Wire.endTransmission(); //end transmission
//reads bytes
void readFrom(byte address)
      Wire.send(address); //sends address to read from
      Wire.endTransmission(); //end transmaission
        Wire.requestFrom(0x53,1); //request bytes from device
      char message = Serial.read();
      if (message == 'r') {
            slipOut(readFrom(0x32)); //read x lsb
            slipOut(readFrom(0x33)); //read x msb
            slipOut(readFrom(0x34)); //read y lsb
            slipOut(readFrom(0x35)); //read y msb
            slipOut(readFrom(0x36)); //read z lsb
            slipOut(readFrom(0x37)); //read z msb
            Serial.print(delimiterChar, BYTE);
void slipOut(byte output) //slipout to max/msp
      if ((output==escapeChar)||(output==delimiterChar)) Serial.print(escapeChar, BYTE);
      Serial.print(output, BYTE);
Thanks for any help!
Best
It would probably be helpfull if you took the time to actually tell us what your problem is and how it manifests itself.
I found it out!
I got two problems:
The first is that I was calling the function slipOut(byte output) on the output of the function readFrom(byte address) but the readFrom function was declared to have no output (void). The second problem is that I was not actually reading the i2c line after requesting the sensor data.
#include <Wire.h>
      Wire.begin(); //join i2c bus (address optional for master)
      //turning on the ADXL345
      writeTo(0x2D, 0);
      writeTo(0x2D, 16);
      writeTo(0x2D, 8);
//read bytes
byte readFrom(byte address)
      byte temp = Wire.receive();
      return temp;
