i2c problems with an I/O expander
Hello folks!
I’m experiencing some problems with an i2c I/O expander. I’m trying to use an Uno to control the device but somehow it won’t work.
The device, TCA9554
I’ve set the Adress to 111. Which means that the controll code + adress is equal to 3F.
So when i try to use it as an output expander I’m not able to control the outputs. That is, the outputs are high no matter what I send to it.
I know that connection is established since if I change the adress I do get NACK instead of ACK. Pics from my logic analyzer to proove it. Same sequence but different adresses. Correct adress gives ACK.
Start - send adress + r/w = 0, 3F << 1 = 7E - send CMD to use output ports, 0x01 - Stop
Arduino code
#include <Wire.h>
#define exp_address 0x3F
  Wire.begin(); // join i2c bus (address optional for master)
void expander()
  Wire.beginTransmission(exp_address); //Choose expander
  Wire.write(byte(0x01)); // Output ports
  Wire.write(byte(0x00)); // Send Data 8 bits, first 4 bits to switch on the switches 0 = ON
  Wire.endTransmission();     // stop transmitting
  expander();
I suppose I’ve missed something important. But it’s friday… :slight_smile:
Any help is appreciated!
