hi, i am interfacing SureElectronic's Dual-axis magnetic sensor, and i cant "translate" datasheet instructions into the Wire library command. Please help.
thanks for the info, (in the example it says 0x60 somewhere),
but the thing is still not working as it should. i keep getting the same data: 0 0 16 0 128 27
i dont understand the cycles to get the 5 byte data form the chip. Please help
Yes it says that once in the data sheet but all the other times it referrers to the address it shows a binary value of 0x30.
have you tried 0x30 ?
It is odd that you get a pattern of 6 values as there are only 5 internal registers.
Anyway you are not writing a "1" into the device to initiate a data conversion cycle. Therefore you keep reading back the last value.
I would change the code so that you read all five bytes at a time as well as writing the "Take measurement" bit into it.
Then as it says in the application note cited at the end of the data sheet a set and reset of the coils might be required. However I would write a separate sketch to do this once in the setup and not incorporate it into your normal sketch.
hi, i know i should "write 00000001" to indicate the data aquisition but the problem is i dont know how to "write" or "read" or "start","stop" or how to "send acknowledge" in terms of Wire library. I have read the Reference (and the manual for this sensor like 10times) but still i cant piece them together.
#include <Wire.h>
int val[5]; // array to hold your data
Wire.begin(); // start the I2C interface
int i;
// first send 0x01
Wire.beginTransmission(0x30);
Wire.send(0x01);
Wire.endTransmission();
// now read five bytes back
Wire.requestFrom(0x30, 5);
for(i = 0; i<5; i++){
while(!Wire.available()) { } // do nothing until data arrives
val[i] = Wire.receive();
// now print it out
for (i = 0; i<5; i++){
Serial.print(val[i],BIN);Serial.print(" ");
Try giving it the zero memory address pointer like this:-
#include <Wire.h>
int i;
// first send 0x01
Wire.send(0x01); // initilise sequence
Wire.send(0x00); // zero memory address pointer
// now print it out
SDA and SCL could do with external pullups of about 4K7 but in this case I do think we are talking to the device, it's just we are not doing it write. The data sheet is not too clear on this.
It does say the 4 MSBs should be zero and we are seeing this.
Also try the 0x60 address again.
i have also been experimenting with beginTransmission, endTransmission placements, but no luck so far. This thing is really frustrating..
(also with address 0x60, i get nothing)
i have sent an email to the SureElectronics' tech department requesting an example for this sensor, here is the C example:
void getMagValue(void)
{ int a;
i2c_Open(0b01100000,I2C_WRITE);
DelayUs(10);
i2c_PutByte(0b00000000);
DelayUs(10);
i2c_PutByte(0b00000001);
DelayUs(10);
i2c_Stop();
for(a=0;a<600;a++)DelayUs(100);
i2c_Start();
i2c_PutByte(0b01100001);
b[0]=i2c_GetByte(I2C_MORE);
b[1]=i2c_GetByte(I2C_MORE);
b[2]=i2c_GetByte(I2C_MORE);
b[3]=i2c_GetByte(I2C_MORE);
b[4]=i2c_ReadByte();
i2c_Stop();
And there may be something wrong with your program, Wire.beginTransmission(0x30);.
The 0x30 should be 0x60.
can you please help me translate this into an Wire library code?
