I2C protocol to Connect two Arduino
Hi everyone,
I need to connect two Arduino together. So I have to use the I2C Protocol.
In the Slave part we need to both send and receive data to and from Master.
I've learned for receiving the data from master I have to add the following code in the void setup section:
Wire.onRequest(requestEvent);
Also for receiving data from Master I have to use the following code in the void setup section:
Wire.onReceive(receiveEvent);
The question that can I add both of them in order to send receive data?
Thanks
Mahdiyar
Yes. What happened when you tried it?
Mahdiyar:
Assuming that you want to communicate between UNO (I2C-Master) and NANO (I2C-Slave), then you have the following hardware setup.
Figure-1:
Slave will send data to Master when Master sends a request command to the Slave by executing the following code which must be included in the Master sketch:
Wire.requstFrom(slaveAddress, numberOfDataBytesRequestedd);
I've learned for receiving the data from Slave I have to add the following code in the void setup section of Master:
Also for receiving data from Master I have to use the following code in the void setup section of the Slave sketch:
And then define the declare/define the following function after loop() function of the Slave sketch:
void receiveEvent(int howMany)
    //put codes here as needed
The question is not clear to me.
