I2C question
Hello!
I am working on I2C communication between Mega(MASTER) and UNO(SLAVE) to send a simple character from one to the other.
I have written the following code, but I am not sure if it is written correctly. Please take a look and let me know if I wrote it right, and if not what changes I need to make.
Mega (MASTER) code:
//This code is for MEGA (Master). The Mega will send a single
//variable to the UNO and let it carry out a pre-set program in the UNO
#include<Wire.h>    //library for I2C communication
   Wire.begin(); //join i2c bus
   Wire.beginTransmission(3);	//transmit to device #3, the waveshield
   Wire.write('X');		//send a single byte to the arduino UNO
   Wire.endTransmission();	//stop transmitting
   delay(500);			//delay to help buffer out
NOTE: If this needs to be a function, then do the following:
void Arduino_Trans()
UNO (SLAVE) Code:
//Slave set up for the UNO. It will receive a character from the MEGA
//and execute its program.
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
   Wire.begin(3);	//join i2c bus with address #3
   Wire.onReceive(receiveEvent);	// register event
   delay(100);	//delay to help buffer
void receiveEvent(int howMany)
   while(1 < Wire.available())   //loop through all but the last
   char c = Wire.read();   //receive byte as a character
   //Serial.print(c);     //print character only for debugging
   if(c =='X')
   Serial.println("Hello World!");
NOTE: I am initializing several libraries because I will be expanding the slave program as soon as I verify that it actually works..
Thank you,
Yesenia
If it were me, I'd just try it and see if it works. Did you do that?
It would probably be a good idea to include the wire library at the slave end.
