i2c question
Hiya,
dont know if this is the right place to ask but i guess.
I've got a question about the i2c protocol.
My idea,
I want to hold a master arduino which controls multiple slaves.
The master is communicating with the World Wide Web through a password protected website.
From the website i do click a relais and then the master must communicate with the slave device with that relais to toggle.
But i cant really find out if its possible to send a request to a slave adress with a extra data so it just toggle 1 relais instead of all the relais who are on the arduino..
Is that possible and could maybe someone tell me how., or knows a way to do it on a another way.
Hopefully someone could help me.
Greetings,
Spikie
this might help to get started - http://arduino.cc/en/Tutorial/MasterReader -
Thanks for your response.
But thats what my problem is..
If you start with the master a i2c request to a number ( slave id) then the slave just do a programmed loop..
What i want is that i send the slave id + a extra command and that the slave reads that he is that ID and he reacts to the extra command so a relais 1 goes in.
example:
master got 3 slaves on the line.
Slave 1 got 3 relais on his atmega.
Master says Slave ID 1 relais 2.
Slave 1 : digitalWrite( 3, HIGH);
and the rest of the relais need to be on the state they were.
Master says Slave ID 2 Relais 1
Slave 2 digitalWrite(1,HIGH);
and i really cant find the way i give that extra command and the slave the read of an extra command.
Greets,
Spikie
OK I got it,
needs some checking to do
BRB
// not tested but this is how I would start it, you should get the idea.
#include <Wire.h>
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  Wire.beginTransmission(2);
  Wire.write(10);  // command code  or other command.
  int rv = Wire.endTransmission();
  while(Wire.available())    // slave may send less than requested
    char c = Wire.read(); // receive a byte as character
    Serial.print(c);         // print the character
  delay(5000);
// also not tested :slight_smile:
  Wire.begin(2);                // join i2c bus with address #2
  while(Wire.available() == 0);  // wait for request
  int command = Wire.read();
  switch(command)
     case 10: // handle command 10
      Wire.write(sensor.value);
     case 11: // handle command 11
      RelayON();
      Wire.write(relay.state);
     case 12:
      RelayOFF();
    default:
You just need to setup up your own communication protocol. I would just send it a byte with which relays to turn on as individual bits.
robtillaart:
OK I got it,
BRB
#include <Wire.h>
  delay(5000);
// also not tested :)
  switch(command)
      RelayON();
     case 12:
      RelayOFF();
    default:
YAY! thats it! gonna test it tomorrow on my workplace but i didnt see the read and write!:smiley: thanks alot !
was already thinking of using rs232 and then all the rx's of the slaves togheter and then let the master talk with a write 1 for slave 1 and next the command i want. but this is better! :smiley: thanks alot!
Greets,
Spikie
Please post the code when you got it really working for future reference,
Thanks
Well, im trying at the moment but something happens what i dont understand.
i did abit of changing the code to get it working but its not really getting that far.
i've changed the slave code to
#include <Wire.h>
  while(Wire.available() == '0');  // wait for request
Serial.println(command);
i changed so i could read out what is comming from the read. also i did change the
  while(Wire.available() == '0');  // wait for request, the 0 between ' ' =)
otherwise it isnt even working..
I do get out of my serial this:
-1
-1
-1
and futher.
Maybe you know what happens?
EDIT:
after long searching i still doesnt know what happens.. it looks like they dont understand each other.. and it gets wrong on the slave side, i guess.. i can only see what he does after the wire.read cause i can print that in serial... does anyone knows an other idea?
For those who wanted to know how it works by now, i've made it as i wanted and going futher in the raspberry pie but that wasnt the problem;)
here is the code for Master arduino.
int val = 4; // random value
#include <Wire.h>
  Wire.begin();
  Wire.beginTransmission(10); // start talking to slave 10.
  Wire.write(val);
and this for the slave's with all diffrent adresses;)
#include <Wire.h>
int c;
  pinMode(2,OUTPUT);
  pinMode(4,OUTPUT);
  Wire.begin(30);
    Wire.onReceive(info); // when the master is talking to this slave.
void info(int command){
  c = Wire.read();
  Serial.println(c);
  if (c == 2){
    digitalWrite(2,HIGH);
  else{
    digitalWrite(2,LOW);
  if (c == 4){
   digitalWrite(4,HIGH);
  }else{
   digitalWrite(4,LOW);
