since the device has only two options, you could make a bunch of pro-mini boards and then network them together.
the ESP8266 offers the software choice as was pointed out, and I would assume the newer ESP32 with it's 32 GPIO pins might offer up to 32 sensors if you can put 2 sensors on a 2-pin bus.......
Wawa:
Datasheet tells me that these sensors can be set to two addresses.
1101000 when AD_select is connected to ground, and 1101001 when connected to VDD.
if I used digital pins to supply 5v to ADO on the break out board of the sensor it will be 1101001.
if I write that pin low will 0v act as gnd and make it 1101000???
I'm curious about this sensor. Some applications are suggested in the data sheet, but it doesn't explain what advantages this particular sensor brings to those use cases. There are not enough pixels to form a useful infrared image. If you want to measure objects' temps, you don't need 64 answers. If you want to detect moving warm objects, a far cheaper PIR sensor will do that. Someone please let me into the secret!
LandonW:
but what exactly does that do? shut off the sensor or stop communication or what?
and why would the unit/sensor need interrupted?
It's the other way around: the sensor producing an interrupt. Normally by changing the INT line from LOW to HIGH or the other way around upon certain events - check data sheet for details. Your MCU can respond to this, if you connect this line to one of your IO pins and create an interrupt for it in your sketch.
Even those "standard" sensors come with part numbers and data sheets. What you believe to be "standard" may be just one of several very similarly looking devices.
wvmarle:
"Common" rather than "Standard" is the word I should have used. Or "bog-standard"
LandonW:
that style isn't suitable for my project. too bulky and similar ones that are smaller wont work either.
Well, if the application is a secret, there is only so much help you can get on a forum and you have to accept that you will get suggestions that are not helpful.
