I2C read - is there anything wrong with this code?
Because I am getting back nothing but 255 (0b11111111) from the device and I don't understand why.
m_nDevAddrRead == 3Dh as per the data sheet.
What AM I doing wrong?
uint8_t Adafruit_Sensor::readReg8(uint8_t nRegAddr)
	uint8_t nValue;
	Wire.beginTransmission(m_nDevAddrRead);
	#if ARDUINO >= 100
		Wire.write(nRegAddr);
	#else
		Wire.send(nRegAddr);
	#endif
	Wire.requestFrom(nRegAddr, (uint8_t)1);
	#if ARDUINO >= 100
		nValue = Wire.read();
	#else
		nValue = Wire.receive();
	#endif
	Wire.endTransmission();
	Serial.print("nValue = ");
	Serial.print(nValue, BIN);
	Serial.println("");
	Serial.print("nRegAddr = ");
	Serial.print(nRegAddr, HEX);
	Serial.println("");
	Serial.print("m_nDevAddrRead = ");
	Serial.print(m_nDevAddrRead, HEX);
	Serial.println("");
	return nValue;
First thing that I always do is run the I2C scanner to confirm the address and communication.
Are you including Wire.h in your .ino file? Do you have Wire.begin() in setup?
// I2C scanner by Nick Gammon.  Thanks Nick.
#include <Wire.h>
  Serial.begin (115200);
  // Leonardo: wait for serial port to connect
  while (!Serial)
  Serial.println ();
  Serial.println ("I2C scanner. Scanning ...");
  byte count = 0;
  Wire.begin();
  for (byte i = 1; i < 120; i++)
    Wire.beginTransmission (i);
    if (Wire.endTransmission () == 0)
      Serial.print ("Found address: ");
      Serial.print (i, DEC);
      Serial.print (" (0x");
      Serial.print (i, HEX);
      Serial.println (")");
      count++;
      delay (1);  // maybe unneeded?
      } // end of good response
  } // end of for loop
  Serial.println ("Done.");
  Serial.print ("Found ");
  Serial.print (count, DEC);
  Serial.println (" device(s).");
}  // end of setup
void loop() {}
I ran the device scanner sketch and get 1E depending with the SDO pin low.
I have checked the return value from Wire.endTransmission() on my regRead(...) and regWrite(...)
functions and I get 0 / successful.
But no matter what damn register I read I get a return value of FF / 255., including the WHO_AM_I register / 0Fh.
So what could I possibly be doing wrong?
If I download the adafruit LSM303D library I can get some sensible output out of it although it seemed a bit 'jumpy'.
But as soon as I use my own library I get nothing.
Here is my readReg(...)
uint8_t CSensor::readReg8(uint8_t nRegAddr)
	uint8_t nValue;
	#if ARDUINO >= 100
	#else
	#endif
	#if ARDUINO >= 100
	#else
	#endif
	m_nWireError = Wire.endTransmission();
	Serial.println("@@@@@@@@@@@@@@@@@@@@@");
	Serial.println(nRegAddr, HEX);
	Serial.println(m_nDevAddrRead, HEX);
	Serial.println("");
	Serial.println(m_nWireError);
	Serial.println("");
	Serial.println(nValue, HEX);
	return nValue;
The out out of those println(...) calls is as follows.
Correct register address.
Correct device address.
No error condition.
But total garbage as the contents of the register.
F
1E
0
FF
I changed my I2C readReg(...) to the following to try and get more info.
bool CSensor::dataReady(uint8_t nNumBytes)
	uint32_t nMillisStart = millis(), nDeltaMillis = 0;
	m_nWireError = 0;
	while ((Wire.available() < nNumBytes) && (m_nWireError == 0))
Serial.println(nDeltaMillis);
Serial.println(Wire.available());
Serial.println(m_nI2CTimeOut);
Serial.println("");
		nDeltaMillis = millis() - nMillisStart;
		if (nDeltaMillis > m_nI2CTimeOut)
			m_nWireError = 5;
	return m_nWireError == 0;
	uint8_t nValue = 0;
	#if ARDUINO >= 100
	#else
	#endif
	if (m_nWireError == 0)
		if (dataReady(1))
			#if ARDUINO >= 100
			#else
			#endif
			Serial.println("");
			Serial.println("");
			m_nWireError = 5;
	return nValue;
In the serial monitor that dataReady(...) function counts all the way up to 2000 ms with wire.available() always returning 0.
So I just don't get it.
What is the fundamental difference between my code and the code above from the similar code in the LSM303 library that does work with my device????? I just can't see it!
// Reads the 3 accelerometer channels and stores them in vector a
void LSM303::readAcc(void)
  Wire.beginTransmission(acc_address);
  // assert the MSB of the address to get the accelerometer
  // to do slave-transmit subaddress updating.
  Wire.write(OUT_X_L_A | (1 << 7));
  last_status = Wire.endTransmission();
  Wire.requestFrom(acc_address, (byte)6);
  unsigned int millis_start = millis();
  while (Wire.available() < 6) {
    if (io_timeout > 0 && ((unsigned int)millis() - millis_start) > io_timeout)
      did_timeout = true;
      return;
  byte xla = Wire.read();
  byte xha = Wire.read();
  byte yla = Wire.read();
  byte yha = Wire.read();
  byte zla = Wire.read();
  byte zha = Wire.read();
  // combine high and low bytes
  // This no longer drops the lowest 4 bits of the readings from the DLH/DLM/DLHC, which are always 0
  // (12-bit resolution, left-aligned). The D has 16-bit resolution
  a.x = (int16_t)(xha << 8 | xla);
  a.y = (int16_t)(yha << 8 | yla);
  a.z = (int16_t)(zha << 8 | zla);
boylesg:
m_nWireError = 0;
Serial.println("");
m_nWireError = 5;
uint8_t nValue = 0;
#if ARDUINO >= 100
#else
#endif
if (dataReady(1))
#if ARDUINO >= 100
#else
#endif
Serial.println("");
Serial.println("");
m_nWireError = 5;
return nValue;
     did_timeout = true;
     return;
Your are not using the Arduino's I2C Wire.h library correctly.
// to send data to a device.
Wire.beginTransmission(byte); // address of I2C (7bit value 0x08 .. 0x78) 0x00..0x07 and 0x79..0x7F are reserved for special function,  You can uses them at your parel.
Wire.write(byte);  // the byte to send, limited to 31 bytes at a time.
Wire.endTransmission();  // actually do the I2C transaction.
//to Receive data from a device
Wire.requestFrom(byte,byte); // the first byte is the 7bit I2C address, the Second is howmany byte to request.
  // a maximum to 31 is possible at one time.
while(Wire.available()){ // available returns a count of bytes in input buffer
  char ch = Wire.read();
Don't put Wire.endTransmission() after Wire.requestFrom().
Chuck.
I figured it out - I used the register address in Serial.requestFrom(...) rather than the device address.
