I'm learning I2C communication, or trying to...
I'm working with an MPU9250 9DoF Accelerometer/Gyroscope/Magnetometer
Datasheet attached
I'm going to briefly go through my understanding of I2C and how to setup a device because the problem may be in here:
For reading from the device:
- I get a new device that will communicate using I2C
- connect SCL and SDA lines between device and arduino
- (using the wire library) I send the device address and a R bit (1) (wait for the ACK bit from the device), then send the RA (register address)(wait for the ACK bit from the device), then the device sends back the data from that register
That may be an overly simple explanation.
So the Device Address and the Register Addresses should be in the datasheet, no?
But my datasheet doesn't have anything listed like addresses, and I can't find them online so I'm doubting my understanding of I2C.
Is it a poorly made datasheet? Or (more likely) am I missing something?
PS-MPU-9250A-01.pdf (655 KB)
Google "I2C Scanner Arduino". The I2C scanner will report the address of any I2C device that it finds.
Google "MPU9250 Arduino". There is already a library that knows how to read that device.
Thanks! The I2C scanner helped a bit.
I found the Register Address document, and have attached it. (for some reason googling "MPU9250 Arduino wouldn't find it, had to search MPU 9250 Register Address)
Yeah I saw that, but it's actually for the MPU9150, I checked that the addresses in the sketch match those in the document and they seem to for the most part. The "I2C Scanner" helped me figure out if it was 0x68 or 0x69 (it was 0x68)
But then I still get no data...
Wish I had some better resources for learning I2C...
RM-MPU-9250A-00.pdf (508 KB)
Nevermind! I just picked up my breadboard and touched a wire and suddenly a bunch of data started coming through. Guess I might need a new breadboard, this one's getting a little loose (and maybe rusty inside)
