Hello,
I am using an arduino mega to send an array of temperature sensors to an arduino uno via i2c, which is working fine in solitary. I also want this arduino mega to get a time from a ds1307 rtc for display on a screen. The mega was getting the time from the RTC using setSyncProvider(RTC.get) in setup() and then using the time library function such as minute() in the main loop - this was also working fine in solitary. However, when I tried to merge the two functions together the code is no longer functional after the setup, resulting in a significant slow down and eventual stopping in the main loop.
I am relatively new to Arduino and the coding environment but am assuming that this slow down has to do with a possible master/slave issue on I2C. The address of the Uno has been set as 4 and the default address of the RTC is different (I looked up the Maxim datasheet).
I would attach the code but the main file is large (>900 lines) so I am putting this up here to see if anyone else had a similar issue first before editing the code down to a minimal and (understandable!) file!
Any help appreciated!
Thanks
Aodhgan
