I2C same addresses w/ multiplexer problems
Hey all,
I am currently having some trouble with an Arduino project. These are the sensors/hardware that I am using:
mpu6050 breakout board (https://www.sparkfun.com/products/11028)
sensorstick 9dof breakout board (https://www.sparkfun.com/products/10724)
Flexiforce pressure sensor-just in analog pin
16 channel multiplexer (https://www.sparkfun.com/products/9056)
Arduino Due
What I want to do is read raw data from these sensors simultaneously (or close to). I have been able to read data off of each sensor individually and I have been able to read data off of them all at once but not consistently. I know this is probably something to do with my multiplexer or arduino code. The biggest problem now is that I am able to only read data from one mpu6050 as they both share the same address. The address is hard wired so I don’t want to change the address which would require desoldering and soldering (I’m not very skilled with soldering!). I will eventually be using 5 mpu6050 sensors so I cannot just set one high one low and put them on sda,scl and sda1,scl1. I would really really appreciate any help on the subject. My code is attached.
Thank you in advance for any help!
mpu6050_sensorstick_flexiforce.ino (8.25 KB)
Did you know about this 'trick' : http://playground.arduino.cc/Main/MPU-6050#multiple I did not read your sketch, I would like to know how the multiplexer is connected.
Peter_n. Thanks for the reply! I have actually seen this and the problem is that the ado pin of the mpu6050 sensors that I am using are soldered to gnd so they cannot be changed without desoldering this connection. I actually have been able to achieve a more reliable result in the past few days. In my original code I had not initialized the mpu6050 when a channel was switched. I appreciate your suggestion!
