[I2C] Save received string
I sending from "arduino 1" to "arduino 2" string (HI) and received like that:
void DaemonReceiving(int howMany){
  Serial.print("RECEIVED: ");
  while(Wire.available() > 0){
    char c = Wire.read();
    Serial.print(c);
Ok, I see "RECEIVED: HI". So, now I want write HI to char* variable. When I make:
char dataRx[10] = "";
    strcat(dataRx, c);
I get error "Invalid conversion from 'char' to 'const char*'. Where is the problem and how I can write received string to a variable?
Where you try to use a character where a string is expected.
All that code happens in a loop. Create an index variable (int), initialized to 0. Every time you read a character, add it to the array, increment the index, and add a NULL.
  int index = 0;
    Serial.print(c);
    dataRx[index++] = c;
    dataRx[index] = '\0';
Yes, this is good reason :smiley: Thnx for your help! When it works I have another problem :slight_smile:
  int index = 0;
  Serial.println(dataRx);
  if(strcmp(dataRx, "HELLO") == 0){
        Wire.beginTransmission(1);
        Wire.write("HI");
        Wire.endTransmission();
When this condition is met, uC freezes on Wire.(...) commands :-/
