Does anybody have succeed doing I2C scan at 400k?
I download the sketch from internet
this one
Preformatted text
#include<Wire.h>
void setup(){
Wire.begin();
Serial.println("I2C scanner is ready.");
// scanI2C(100000);
scanI2C(400000);
// scanI2C(1000000); // uncomment if the microcontroller supports this speed
// scanI2C(3400000); // uncomment if the microcontroller supports this speed
// scanI2C(5000000); // uncomment if the microcontroller supports this speed
Serial.println("****************************");
delay(10000);
void scanI2C(long frequency){
String normal = "standard mode (100 kHz):";
String fast = "fast mode (400 kHz):";
String fastPlus = "fast mode plus (1 MHz):";
String highSpeed = "high speed mode (3.4 MHz):";
String ultraSpeed = "ultra fast mode (5.0 MHz):";
String defaultStr = " !!!!! This speed is not supported !!!!!";
bool error = true;
bool addressFound = false;
Serial.print("Scanning in ");
switch(frequency){
case 100000:
Serial.println(normal);
case 400000:
Serial.println(fast);
case 1000000:
Serial.println(fastPlus);
case 3400000:
Serial.println(highSpeed);
case 5000000:
Serial.println(ultraSpeed);
default:
Serial.println(defaultStr);
Wire.setClock(frequency);
for(int i=8; i<128; i++){
Serial.println(i,HEX);
Wire.beginTransmission(i);
error = Wire.endTransmission();
if(error == 0){
addressFound = true;
Serial.print("0x");
if(!addressFound){
Serial.println("No I2C device found");
it work ok on 100000, but if I try to used at 400000 it generated the clock total random ... not 50 duty as i2c supposed to be, the time is not 2.5ms as expected for 400000 and if freeze the Arduino ... don't complete the loop
so how to make Arduino uno to really run i2c on 400000?
