I2C send and recieve
Hello, I am currently trying to create a program that can be used to send and recieve data using I2C communication. I have the function mostly correct and all it is supposed to do is send 8 bits and then the other prints those 8 bits. But my error is sketch_oct22a:4: error: variable or field ‘myhandler’ declared void. Any advice?
#include <Wire.h>
  int MOBO = 00000001;
  int PAYLOAD = 00000010;
  int ATTITUDE = 00000011;
  int COMM = 00000100;
  int POWER = 00000101;
  Wire.begin(MOBO);
  Wire.onReceive(myhandler);
  Serial.println("Enter the address of the target ard.");
  int TARGET = Serial.read();
  Serial.println("Enter the function you want to send.");
  int function = Serial.read();
  Wire.beginTransmission(TARGET);
  Wire.write(function);
  Wire.endTransmission();
void myhandler(8){
  char incomingfun[8];
  while (Wire.available()){
	for (i = 0; i < sizeof(incoming) - 1; i++){
	incoming[i] = Wire.receive();
    Serial.print(incoming);
void myhandler(8)
This... should be void myhandler(int something).
Serial.println(“Enter the address of the target ard.”);
  Serial.println(“Enter the function you want to send.”);
Trouble brewing here, too.
So now it's mostly compiled, I still don't understand what trouble is brewing in the loop but hey I will get to that some time. But now it is saying "C:6: error: expected ',' or '...' before numeric constant"
Really? But your code is a secret?
How to use this forum
As for trouble brewing: http://www.gammon.com.au/serial
You are reading data before it arrives. Plus you can't read multiple digits like that.
ATTITUDE is not decimal 11 here. It is decimal 9.
Proof:
void setup ()
  Serial.begin (115200);
  Serial.println ();
  Serial.println (ATTITUDE);
  }  // end of setup
void loop () { }
Output:
9
This is my code so far, after a bit of back and forth binary addresses changed to hex. Sorry for not posting this with my first reply
#include <Wire.h>
  int MOBO = 0x01;
  int PAYLOAD = 0x02;
  int ATTITUDE = 0x03;
  int COMM = 0x04;
  int POWER = 0x05;
  Wire.begin(MOBO);
void myhandler(int 8){
  int i = 0;
	for (i = 0; i < sizeof(incomingfun) - 1; i++){
	incomingfun[i] = Wire.read();
    Serial.print(incomingfun);
This hasn't a hope of working. Read my link above about serial please.
If you want to “block” and get a line of entered text this is closer to what you want:
// get a line from serial
//  ignore spaces, tabs etc.
//  forces to upper case
void getline (char * buf, size_t bufsize)
byte i;
  // discard any old junk
  while (Serial.available ())
    Serial.read ();
  for (i = 0; i < bufsize - 1; )
    if (Serial.available ())
      int c = Serial.read ();
      if (c == '\n')  // newline terminates
      if (!isspace (c))  // ignore spaces, carriage-return etc.
        buf [i++] = toupper (c);
      } // end if available
    }  // end of for
  buf [i] = 0;  // terminator
  Serial.println (buf);  // echo what they typed
  }     // end of getline
Then:
  char response [10];
  getline (response, sizeof response);
  int TARGET = atoi (response);
Hey thanks, your website is very interesting by the way. If I understand you correctly then this code will correctly process target, but int function will not work?
Some code provided by: Nick Gammon
#include <Wire.h>
#define MOBO  0x01
#define PAYLOAD 0x02
#define ATTITUDE  0x03
#define COMM  0x04
#define POWER  0x05
  Wire.begin(MOBO);
byte i;
    Serial.read ();
    }  // end of for
  }     // end of getline
  char response [8];
void myhandler(int  howMany){
  int i = 0;
Why do you say that?
  int i = 0;
Don’t do serial prints inside an ISR.
See my I2C stuff:
http://www.gammon.com.au/i2c
Well my reasoning is that while I changed the code for int target, I didn’t change the code for int function which, I assume since they both are just from serial, that int function will not work correctly. Because the code for int function doesn’t use getline.
  int i = 0;
Well, yes. You were supposed to change that, from the example for TARGET:
  char response [8];
  int function = atoi (response);
You should read this part: I2C summary
Example of requesting data from a slave:
  byte buf [10];
  if (Wire.requestFrom (SLAVE_ADDRESS, 10) == 10)  // if request for 10 bytes satisfied
    for (byte i = 0; i < 10; i++)
      buf [i] = Wire.read ();
    // failure ... maybe slave wasn't ready or not connected
