Hi there, here is what I'm trying to accomplish. I have a master device and a slave device connected via I2C. Master has an ultrasonic sensor measuring the distance and sends a an integer "1" to slave device when the distance is <15cm. The slave should receive the sent integer and do something accordingly. In my example below, I only turn on an LED when the distance is < 15cm. However, I cannot get this code working and I couldn't figure out why. I would very much appreciate if someone can point out what I'm doing wrong.
Thank you.
-----Master code-----
#include <Wire.h>
#define trigPin 13
#define echoPin 12
int duration, distance;
Wire.begin();
Serial.begin(19200);
delay(50);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
digitalWrite(trigPin, HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration / 2) / 29.1;
if (distance > 1 && distance < 15) {
Wire.beginTransmission(2); // transmit to device #2
Wire.write(1); //send 1 to slave
Wire.endTransmission(); // stop transmitting
-----Slave Code-----
#include <Wire.h>
int led = 13;
int receivedValue;
Wire.begin(2); // join i2c bus with address #2
Wire.onReceive(receiveCall); // register event
pinMode(led, OUTPUT);
void receiveCall(int byteCount) {
if (byteCount == 1) {
receivedValue = Wire.read();
receivedValue |= Wire.read();
if (receivedValue == 1) {
digitalWrite(13, HIGH);
