I2C Sending and Receiving on one Arduino without delay
Hi everybody!
I have a problem that I can't find an answer for, I'm sorry if it has been asked before but couldn't find a thread on it yet:
I have two arduino unos connected by i2c, one is the slave (motor controller) and one the master. now what I want to do is send commands to the slave and read back sensor data (constantly). problem is I can only do either reading or writing (commenting the code out... then either one works)
first I send my command (which is received successfully), then wait 500ms then try to receive but I never get an answer.
now I assume that higher delay times would help here? that would be bad though since I rely on very up to date data and I even want to read some more sensors over a sensor expansion board...
any ideas? do you need to see the code?
thanks for any help!
You probably won't get much help unless you do. I recommend posting the master and slave sketches.
thanks SurferTim! I figured it out now though, the problem was somewhere else in my code ::) hours of searching for the bug and then it's completely unrelated ... duhh..
ok case closed ;)
